[pgrouting-users] Many to many routing and traffic assignment
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Apr 7 05:46:26 PDT 2014
On 4/7/2014 5:13 AM, Lyubomir Klyambarski wrote:
> Dear pgrouting users,
> I am begginer at using pgrouting and SQL as a whole, but this tool would
> be very useful for my projects. My task is to perform traffic assignment
> on the road network of Bulgaria. I use routable map prepared with
> Osm2po. My start/end points are defined according to the map nodes.
> Using the code from the example
> SELECT seq, id1 AS node, id2 AS edge, cost FROM pgr_dijkstra('
> SELECT id,
> source,
> target,
> cost
> FROM osm',
> 30, 60, false, false);
> how can I read my start/end points from another table and attach traffic
> value to the edges in new column?
> Thanks in advance.
Untested:
See the results:
select a.start, a.end, sum( (pgr_dijkstra(
'SELECT id, source, target, cost FROM osm',
a.start, a.end, false, false)).cost ) as cost
from routes a;
Update the cost column in routes:
update routes set cost=sum( (pgr_dijkstra(
from (select start, stop from routes) a
where routes.start=a.start and routes.end=a.end;
You might need to fiddle with the sql a little but this should give you
the idea.
-Steve
More information about the Pgrouting-users
