[pgrouting-users] Matching edges with its raw GPS traces
    Daniel Kastl
    daniel at georepublic.de
    Tue Apr  8 21:01:04 PDT 2014
Hi Raghavan,
Your GPS data contains a timestamp for each point, right?
So you could first import your points into a table and then make a
LineString from your points, ordered by time.
SELECT ST_MakeLine(pnt_geom) AS geom
    FROM gpstrack ORDER BY timestamp;
And then you could simplify your Linestring to make it look more straight.
That's also a PostGIS function: http://postgis.net/docs/ST_Simplify.html
Daniel
On Wed, Apr 9, 2014 at 12:46 PM, Raghavan Krishnasamylakshmanaperumal <
rkrish20 at uic.edu> wrote:
> I have Runkeeper.com raw GPS traces . I used pgr_nodeNetwork and
> pgr_createTopology to create graph out of this data.
> If I want to match an activity(a user's running record) which has raw GPS
> traces with the edge formed out of it, is there any function in PGRouting
> which can help me to figure out this edge? If there are some edges missing
> due to threshold limits I am fine with it.
> To make it more clear let me also explain my question with a picture
> attached in this email, the black dots are gps traces of my running
> activity, then I used PGRouting to form a graph with this data(just an
> assumption). The green line is the edge corresponding to the black dotted
> gps traces. Now I need to find this green edge matching these black dots
> programmatically.
> So is there any library available in PGRouting which can help me to match
> these raw GPS traces to find its corresponding edge?
> Thanks and Regards,
> Raghavan KL
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140409/569df209/attachment.html>
More information about the Pgrouting-users
