[pgrouting-users] Find vertices away from a specified distance
Ian Tangert itangert at gmail.com
Tue Apr 22 05:17:23 PDT 2014
Raghavan,
You can do this with the Driving Distance functions.  Also, have a look at
the SQL here https://github.com/iant1212/networkReach and here
https://github.com/GregersP/networkReach.  These are examples of returning
all edges for a given distance from a node, you could modify these slightly
to return your vertices, and use your lat/lon to find the closest vertex to
start from.
-ian
On Tue, Apr 22, 2014 at 1:31 AM, Raghavan Krishnasamylakshmanaperumal <
rkrish20 at uic.edu> wrote:
> Hi All,
> I am experimenting with Chicago runner's GPS traces(collected from
> Runkeeper.com). I like to know if the following problem can be solved using
> pgRouting.
> I have created a graph using pgr_nodeNetwork and pgr_createTopology. Given
> a longitude, latitude point I know to find the vertices closer to that but
> I want to know if given a longitude, latitude point can I find the vertices
> away  from a specified distance. Distance here means the lineStrings length
> in meters.
> For example I have a longitude/latitude and want to know all the vertices
> 500meters away from the given longitude/latitude point. Are there functions
> available in pgRouting to infer such vertices?
> Thanks and Regards,
> Raghavan KL
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140422/3f174179/attachment.html>
More information about the Pgrouting-users mailing list
