[pgrouting-users] pgRouting could not get result on Windows7
Daniel Kastl daniel at georepublic.de
Thu Aug 7 01:25:34 PDT 2014
Hi Bomp,
Because you mention "Windows 7" in the subject, do you want to say that it
worked before, for example on Linux?
If you use the sample data of the documentation [1], does it return an
empty table as well? You can run the sample queries [2] to verify it works
or not.
If the sample queries with the sample data work, then you may have a
problem with your data.
Just one remark (which shouldn't prevent you from running pgr_dijkstra
though): your geometry is "multilinestring". If you really have
multilinestrings, then you would have a problem to define source and
target. Otherwise just make it ordinary linestrings.
Best regards,
Daniel
[1]
http://docs.pgrouting.org/2.0/en/doc/src/developer/sampledata.html#sampledata
[2] http://docs.pgrouting.org/2.0/en/src/dijkstra/doc/index.html#examples
On Thu, Aug 7, 2014 at 10:07 AM, sittichai choosumrong <
sittichai.ocu at gmail.com> wrote:
> Dear all,
> I has implemented and install PostgreSQL/PostGIS and pgRouting on windows
> 7 as showing the detail of version belows;
> PostgreSQL = "PostgreSQL 9.3.5, compiled by Visual C++ build 1600, 32-bit"
> PostGIS = "POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel.
> 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
> LIBJSON="UNKNOWN" TOPOLOGY RASTER"
> pgRouting ="(2.0.0,pgrouting-2.0.0,0,d6ed2cb,master,1.46.1)"
> After I create all needed column into my road table then use
> pgr_dijkstra() function. But I could not get the routing result. The table
> showing empty data.
> ### My road data structure is showing below;
> -- Table: public.ways
> -- DROP TABLE public.ways;
> CREATE TABLE public.ways
>   gid integer NOT NULL DEFAULT nextval('ways_gid_seq'::regclass),
>   the_geom geometry(MultiLineString,3857),
>   source integer,
>   target integer,
>   reverse_cost double precision,
>   length double precision,
>   x1 double precision,
>   y1 double precision,
>   x2 double precision,
>   y2 double precision,
>   CONSTRAINT ways_pkey PRIMARY KEY (gid)
> WITH (
>   OIDS=FALSE
> ALTER TABLE public.ways
>   OWNER TO postgres;
> -- Index: public.source_idx
> -- DROP INDEX public.source_idx;
> CREATE INDEX source_idx
>   ON public.ways
>   USING btree
>   (source);
> -- Index: public.target_idx
> -- DROP INDEX public.target_idx;
> CREATE INDEX target_idx
>   ON public.ways
>   USING btree
>   (target);
> -- Index: public.ways_geom_gist
> -- DROP INDEX public.ways_geom_gist;
> CREATE INDEX ways_geom_gist
>   ON public.ways
>   USING gist
>   (the_geom);
> -- Index: public.ways_source_idx
> -- DROP INDEX public.ways_source_idx;
> CREATE INDEX ways_source_idx
>   ON public.ways
>   USING btree
>   (source);
> -- Index: public.ways_target_idx
> -- DROP INDEX public.ways_target_idx;
> CREATE INDEX ways_target_idx
>   ON public.ways
>   USING btree
>   (target);
> What I am missing, any ideas?
> Bomp
> Sittichai Choosumrong (Ph.D)
> Lecturer at Faculty of Agriculture, Natural Resources and Environment,
> Department of Natural Resources and Environment,
> Geography
> 99 Moo 9 Tambon Tha Pho,
> Amphoe Muang
> Phitsanulok Thailand 65000
> Office: +66 55 962753
> Mobile: +66 95-635-8102
> email: sittichaic at nu.ac.th
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140807/62a6003b/attachment.html>
More information about the Pgrouting-users mailing list
