[pgrouting-users] pgRouting could not get result on Windows7
sittichai choosumrong sittichai.ocu at gmail.com
Thu Aug 7 01:37:41 PDT 2014
Hi Daniel,
Now it work!! Thank you. The problem is from my data because the geometry
is "multilinestring"
I have to change to "linestring"
Best regards,
Bomp
P.S. If you need any help about pgRouting workshop on FOSS4G-ASIA in
Thailand this years (http://www.foss4g-asia.org/2014/programmenu/workshops/),
please feel free to tell me what can I help you?
On Thu, Aug 7, 2014 at 3:25 PM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Bomp,
> Because you mention "Windows 7" in the subject, do you want to say that it
> worked before, for example on Linux?
> If you use the sample data of the documentation [1], does it return an
> empty table as well? You can run the sample queries [2] to verify it works
> or not.
> If the sample queries with the sample data work, then you may have a
> problem with your data.
> Just one remark (which shouldn't prevent you from running pgr_dijkstra
> though): your geometry is "multilinestring". If you really have
> multilinestrings, then you would have a problem to define source and
> target. Otherwise just make it ordinary linestrings.
> Best regards,
> Daniel
> [1]
> http://docs.pgrouting.org/2.0/en/doc/src/developer/sampledata.html#sampledata
> [2] http://docs.pgrouting.org/2.0/en/src/dijkstra/doc/index.html#examples
> On Thu, Aug 7, 2014 at 10:07 AM, sittichai choosumrong <
> sittichai.ocu at gmail.com> wrote:
>> Dear all,
>> I has implemented and install PostgreSQL/PostGIS and pgRouting on windows
>> 7 as showing the detail of version belows;
>> PostgreSQL = "PostgreSQL 9.3.5, compiled by Visual C++ build 1600, 32-bit"
>> PostGIS = "POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3924"
>> PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24"
>> LIBXML="2.7.8" LIBJSON="UNKNOWN" TOPOLOGY RASTER"
>> pgRouting ="(2.0.0,pgrouting-2.0.0,0,d6ed2cb,master,1.46.1)"
>> After I create all needed column into my road table then use
>> pgr_dijkstra() function. But I could not get the routing result. The table
>> showing empty data.
>> ### My road data structure is showing below;
>> -- Table: public.ways
>> -- DROP TABLE public.ways;
>> CREATE TABLE public.ways
>>   gid integer NOT NULL DEFAULT nextval('ways_gid_seq'::regclass),
>>   the_geom geometry(MultiLineString,3857),
>>   source integer,
>>   target integer,
>>   reverse_cost double precision,
>>   length double precision,
>>   x1 double precision,
>>   y1 double precision,
>>   x2 double precision,
>>   y2 double precision,
>>   CONSTRAINT ways_pkey PRIMARY KEY (gid)
>> WITH (
>>   OIDS=FALSE
>> ALTER TABLE public.ways
>>   OWNER TO postgres;
>> -- Index: public.source_idx
>> -- DROP INDEX public.source_idx;
>> CREATE INDEX source_idx
>>   ON public.ways
>>   USING btree
>>   (source);
>> -- Index: public.target_idx
>> -- DROP INDEX public.target_idx;
>> CREATE INDEX target_idx
>>   ON public.ways
>>   USING btree
>>   (target);
>> -- Index: public.ways_geom_gist
>> -- DROP INDEX public.ways_geom_gist;
>> CREATE INDEX ways_geom_gist
>>   ON public.ways
>>   USING gist
>>   (the_geom);
>> -- Index: public.ways_source_idx
>> -- DROP INDEX public.ways_source_idx;
>> CREATE INDEX ways_source_idx
>>   ON public.ways
>>   USING btree
>>   (source);
>> -- Index: public.ways_target_idx
>> -- DROP INDEX public.ways_target_idx;
>> CREATE INDEX ways_target_idx
>>   ON public.ways
>>   USING btree
>>   (target);
>> What I am missing, any ideas?
>> Bomp
>> Sittichai Choosumrong (Ph.D)
>> Lecturer at Faculty of Agriculture, Natural Resources and Environment,
>> Department of Natural Resources and Environment,
>> Geography
>> 99 Moo 9 Tambon Tha Pho,
>> Amphoe Muang
>> Phitsanulok Thailand 65000
>> Office: +66 55 962753
>> Mobile: +66 95-635-8102
>> email: sittichaic at nu.ac.th
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.info
Geography
Amphoe Muang
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140807/16720e21/attachment-0001.html>
More information about the Pgrouting-users mailing list
