[pgrouting-users] Wierd results using pgr_kdijkstraPath
AUS - Eyad b00038807 at aus.edu
Thu Dec 18 07:48:38 PST 2014
Here is st_astext(geom) function result (below table).
For both createTopology and nodeNetwork functions, I used "50" as tolerance
because my data unit is in millimeter. However, the network is done on CAD
and fairly not poor in resolution.
Is this what you wanted, or you need another layout/map? I attached many
layouts/maps already in the previous 3 emails.. let me know if you were not
able to visualize
Eyad
-----Original Message-----
[mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Thursday, December 18, 2014 7:26 PM
To: pgrouting-users at lists.osgeo.org
Subject: Re: [pgrouting-users] Wierd results using pgr_kdijkstraPath
Eyad,
What does you geomerty look like?
Select st_astext(geom) from edges limit 10;
What value did you use for tolerance when creating your topology?
What value did you use for tolerance when you noded your network?
-Steve
On 12/18/2014 10:17 AM, AUS - Eyad wrote:
> And here I enclose below the resulted travel_costs' table of
> pgr_dijkstra function:
> Note that Shortest path cost on original network (between the 2 lines of
> the resulted vector feature) is around 250m (below - by converting from
> millimeter to meter) whereas the sum of costs in the above table is
> around 45m only
> Thanks..
> Eyad
> *From:*AUS - Eyad [mailto:b00038807 at aus.edu]
> *Sent:* Thursday, December 18, 2014 7:02 PM
> *To:* 'pgRouting users mailing list'
> *Subject:* RE: [pgrouting-users] Wierd results using pgr_kdijkstraPath
> Here is a prt_sc after trying pgr_dijkstra as follows:
> SELECT seq, id1 as path, (b.geom) as geom, cost FROM pgr_dijkstra(
>      'SELECT id, source, target, (st_length(geom) * 0.001) as cost FROM
> schema.network_noded',
>      336, (SELECT MAX(id) FROM schema.l1_pv1), false, false
>    ) a, schema.network_noded b
> WHERE a.id1=b.id
> As you may see, there is only too little parts of the network's lines
> left (on the sides of the layout)! No route is visible
> Hope this clarifies..
> Eyad
> *Sent:* Thursday, December 18, 2014 6:29 PM
> Hi Daniel,
> Enclosed are 3 maps (1^st prt_sc with the original network, 2^nd & 3^rd
> prt_sc with the resulted network)
> Clearly, the majority of the network has faded away
> Awaiting your feedback, I would work on 2^nd suggestion
> Regards,
> Eyad
> *From:*pgrouting-users-bounces at lists.osgeo.org
> [mailto:pgrouting-users-bounces at lists.osgeo.org] *On Behalf Of *Daniel
Kastl
> *Sent:* Thursday, December 18, 2014 6:28 AM
> *To:* pgRouting users mailing list
> *Subject:* Re: [pgrouting-users] Wierd results using pgr_kdijkstraPath
> Hi Eyad,
> It's difficult to give an answer based on your query and problem
> description only. I guess, that (still) your network topology is not
> correct. It looks like a data problem.
> There are 2 things you could do for now:
> (1) Show us some image of your "weird de-attached "little" pieces"
> (2) Try a simple shortest path query with one start and one end point
> and see if it works with pgr_dijkstra function for example.
> Daniel
> On Thu, Dec 18, 2014 at 7:37 AM, AUS - Eyad <b00038807 at aus.edu
> <mailto:b00038807 at aus.edu>> wrote:
> Hello pgr_Experts,
> I'm trying to get all the routes from a source point (i.e. 336) to a
> group of target/destination points (located at different edges/ends of
> linestrings' network) using the below code:
> SELECT seq, id1 as path, id2 as node, id3 as edge, (b.geom) as geom,
> cost FROM pgr_kdijkstraPath(
> 336, (SELECT array_agg(id) FROM schema.l1_pv1), false, false
> WHERE a.id1=b.id <http://b.id>
> It's resulting a weird de-attached "little" pieces of my original
> nodded_network! However, the number of resulted paths is equal to the
> target/destination points. Please advise:
> 1)What potential mistake I may have committed?
> 2)Does it mean that all the calculated travel_cost(s) are wrong (as they
> are reflected/represented by wrong linestrings)?
> I'm using QGIS 2.4.0 and pgRouting pg93-binaries-2.4.0
> I found similar question on this list of pgRouting users, asked by
> Antonio last October
> (http://lists.osgeo.org/pipermail/pgrouting-users/2014-October/001992.html
> ), but obviously the question is not answered yet?
> Regards..
> Eyad
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.info
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 2015.0.5577 / Virus Database: 4253/8755 - Release Date: 12/17/14
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20141218/d7899afe/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20141218/d7899afe/attachment-0001.jpg>
More information about the Pgrouting-users mailing list
