[pgrouting-users] Wierd results using pgr_kdijkstraPath
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Dec 18 07:26:17 PST 2014
Eyad,
What does you geomerty look like?
Select st_astext(geom) from edges limit 10;
What value did you use for tolerance when creating your topology?
What value did you use for tolerance when you noded your network?
-Steve
On 12/18/2014 10:17 AM, AUS - Eyad wrote:
> And here I enclose below the resulted travel_costs’ table of
> pgr_dijkstra function:
> Note that Shortest path cost on original network (between the 2 lines of
> the resulted vector feature) is around 250m (below - by converting from
> millimeter to meter) whereas the sum of costs in the above table is
> around 45m only
> Thanks..
> Eyad
> *From:*AUS - Eyad [mailto:b00038807 at aus.edu]
> *Sent:* Thursday, December 18, 2014 7:02 PM
> *To:* 'pgRouting users mailing list'
> *Subject:* RE: [pgrouting-users] Wierd results using pgr_kdijkstraPath
> Here is a prt_sc after trying pgr_dijkstra as follows:
> SELECT seq, id1 as path, (b.geom) as geom, cost FROM pgr_dijkstra(
> 'SELECT id, source, target, (st_length(geom) * 0.001) as cost FROM
> schema.network_noded',
> 336, (SELECT MAX(id) FROM schema.l1_pv1), false, false
> ) a, schema.network_noded b
> WHERE a.id1=b.id
> As you may see, there is only too little parts of the network’s lines
> left (on the sides of the layout)! No route is visible
> Hope this clarifies..
> Eyad
> *Sent:* Thursday, December 18, 2014 6:29 PM
> Hi Daniel,
> Enclosed are 3 maps (1^st prt_sc with the original network, 2^nd & 3^rd
> prt_sc with the resulted network)
> Clearly, the majority of the network has faded away
> Awaiting your feedback, I would work on 2^nd suggestion
> Regards,
> Eyad
> *From:*pgrouting-users-bounces at lists.osgeo.org
> [mailto:pgrouting-users-bounces at lists.osgeo.org] *On Behalf Of *Daniel Kastl
> *Sent:* Thursday, December 18, 2014 6:28 AM
> *To:* pgRouting users mailing list
> *Subject:* Re: [pgrouting-users] Wierd results using pgr_kdijkstraPath
> Hi Eyad,
> It's difficult to give an answer based on your query and problem
> description only. I guess, that (still) your network topology is not
> correct. It looks like a data problem.
> There are 2 things you could do for now:
> (1) Show us some image of your "weird de-attached “little” pieces"
> (2) Try a simple shortest path query with one start and one end point
> and see if it works with pgr_dijkstra function for example.
> Daniel
> On Thu, Dec 18, 2014 at 7:37 AM, AUS - Eyad <b00038807 at aus.edu
> <mailto:b00038807 at aus.edu>> wrote:
> Hello pgr_Experts,
> I’m trying to get all the routes from a source point (i.e. 336) to a
> group of target/destination points (located at different edges/ends of
> linestrings’ network) using the below code:
> SELECT seq, id1 as path, id2 as node, id3 as edge, (b.geom) as geom,
> cost FROM pgr_kdijkstraPath(
> 336, (SELECT array_agg(id) FROM schema.l1_pv1), false, false
> WHERE a.id1=b.id <http://b.id>
> It’s resulting a weird de-attached “little” pieces of my original
> nodded_network! However, the number of resulted paths is equal to the
> target/destination points. Please advise:
> 1)What potential mistake I may have committed?
> 2)Does it mean that all the calculated travel_cost(s) are wrong (as they
> are reflected/represented by wrong linestrings)?
> I'm using QGIS 2.4.0 and pgRouting pg93-binaries-2.4.0
> I found similar question on this list of pgRouting users, asked by
> Antonio last October
> (http://lists.osgeo.org/pipermail/pgrouting-users/2014-October/001992.html
> ), but obviously the question is not answered yet?
> Regards..
> Eyad
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.info
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 2015.0.5577 / Virus Database: 4253/8755 - Release Date: 12/17/14
More information about the Pgrouting-users
