[pgrouting-users] Wierd results using pgr_kdijkstraPath
Daniel Kastl daniel at georepublic.de
Thu Dec 18 23:43:11 PST 2014
Hi Eyad,
Looking at just a few of your network images, the network is definitely
broken afterwards. So it's not the fault of the shortest path algorithm.
Without access to the data I can only guess, but often CAD data may contain
geomtries, that don't work well for GIS.
When I look at some screenshots and which parts have been removed, could it
be, that your data contains circles or self-intersecting linestrings for
example?
Daniel
On Fri, Dec 19, 2014 at 4:16 PM, AUS - Eyad <b00038807 at aus.edu> wrote:
> Thanks Steve..
> It seems that I may need to re-install the pgRouting to update the
> "ST_DumpPoints()"?
> Can I split the lines on CAD instead? Then pgr_nodeNetwork() adds nodes
> correctly? Or I may get to same situation if the bug is in the nodding, not
> in splitting lines?
> I have done a cross-check for the pgr_kdijkstraCost and pgr_kdijkstraPath
> results. The cost results are exactly the same. But I'm still not sure if
> the calculated cost is done based on the real shortest_path because I can't
> see the outcome on the map
> If you think that the bug of nodding is only impacting the reflective Path
> outcome? but the Cost outcome is fine? I would rather to complete my
> exercise for now as I'm running out of time.. I can fix this later
> Looking forward to hear your 'practical' expert advice, as I'm still
> beginner
> Thanks again
> Eyad
> -----Original Message-----
> From: pgrouting-users-bounces at lists.osgeo.org
> [mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Stephen
> Woodbridge
> Sent: Friday, December 19, 2014 2:36 AM
> To: pgrouting-users at lists.osgeo.org
> Subject: Re: [pgrouting-users] Wierd results using pgr_kdijkstraPath
> On 12/18/2014 1:51 PM, AUS - Eyad wrote:
> > Also pgr_analyzeGraph function returned in the Messages Tab:
> > NOTICE:              ANALYSIS RESULTS FOR SELECTED EDGES:
> > NOTICE:                    Isolated segments: 7
> > NOTICE:                            Dead ends: 351
> > NOTICE:  Potential gaps found near dead ends: 1
> > NOTICE:               Intersections detected: 62
> > NOTICE:                      Ring geometries: 0
> > I don't know if this is positive or negative, but would like to know your
> > feedback
> > Maybe the isolated segments are lines which are not connected to the
> > network? Is there a way to visualize each group of the above lines?
> So this command adds columns "cnt" amd "chk" to the vertices_tmp table.
> Isolated segments are identified by the fact that both the start and end
> points are dead-ends:
> select *
>    from edges a, vertices_tmp b, vertices_tmp c
>   where a.source=b.id and a.target=c.id and b.cnt=1 and c.cnt=1;
> or maybe:
> select *
>    from vertices_tmp a, edges b
>   where a.chk>0 and st_dwithin(a.geom, b.geom, <distance>);
> Intersections detected indicates you have lines that cross but are not
> noded where they cross. You have to split all lines if they cross and
> make sure there is node at the intersection.
> There is a tool pgr_nodeNetwork() that can help, but there has recently
> been a big found in it and a patch posted with the ticket for the bug.
> https://github.com/pgRouting/pgrouting/issues/280
> -Steve
> > Eyad
> > From: AUS - Eyad [mailto:b00038807 at aus.edu]
> > Sent: Thursday, December 18, 2014 9:54 PM
> > To: 'pgRouting users mailing list'
> > Subject: RE: [pgrouting-users] Wierd results using pgr_kdijkstraPath
> > The function
> > SELECT pgr_analyzeGraph('schema.network_noded',50,'geom');
> > Returned "OK"
> > Feel free to ask for any other details. I know it's not easy to get
> things
> > done remotely.
> > Eyad
> > Woodbridge
> > Sent: Thursday, December 18, 2014 8:25 PM
> > Ok this sounds reasonable.
> > Give this a try:
> http://docs.pgrouting.org/dev/src/common/doc/functions/analyze_graph.html
> > It is hard to diagnose problems remotely via the list.
> > -Steve
> > On 12/18/2014 10:48 AM, AUS - Eyad wrote:
> >> Here is st_astext(geom) function result (below table).
> >> For both createTopology and nodeNetwork functions, I used "50" as
> >> tolerance because my data unit is in millimeter. However, the network is
> >> done on CAD and fairly not poor in resolution.
> >> Is this what you wanted, or you need another layout/map? I attached many
> >> layouts/maps already in the previous 3 emails.. let me know if you were
> >> not able to visualize
> >> Eyad
> >> Woodbridge
> >> Sent: Thursday, December 18, 2014 7:26 PM
> >> Eyad,
> >> What does you geomerty look like?
> >> Select st_astext(geom) from edges limit 10;
> >> What value did you use for tolerance when creating your topology?
> >> What value did you use for tolerance when you noded your network?
> >> -Steve
> >> On 12/18/2014 10:17 AM, AUS - Eyad wrote:
> >>   > And here I enclose below the resulted travel_costs' table of
> >>   > pgr_dijkstra function:
> >>   > Note that Shortest path cost on original network (between the 2
> lines
> > of
> >>   > the resulted vector feature) is around 250m (below - by converting
> from
> >>   > millimeter to meter) whereas the sum of costs in the above table is
> >>   > around 45m only
> >>   > Thanks..
> >>   > Eyad
> >>   > *From:*AUS - Eyad [mailto:b00038807 at aus.edu]
> >>   > *Sent:* Thursday, December 18, 2014 7:02 PM
> >>   > *To:* 'pgRouting users mailing list'
> >>   > *Subject:* RE: [pgrouting-users] Wierd results using
> pgr_kdijkstraPath
> >>   > Here is a prt_sc after trying pgr_dijkstra as follows:
> >>   > SELECT seq, id1 as path, (b.geom) as geom, cost FROM pgr_dijkstra(
> >>   >      'SELECT id, source, target, (st_length(geom) * 0.001) as cost
> FROM
> >>   >      336, (SELECT MAX(id) FROM schema.l1_pv1), false, false
> >>   >    ) a, schema.network_noded b
> >>   > WHERE a.id1=b.id
> >>   > As you may see, there is only too little parts of the network's
> lines
> >>   > left (on the sides of the layout)! No route is visible
> >>   > Hope this clarifies..
> >>   > Eyad
> >>   > *Sent:* Thursday, December 18, 2014 6:29 PM
> pgr_kdijkstraPath
> >>   > Hi Daniel,
> >>   > Enclosed are 3 maps (1^st prt_sc with the original network, 2^nd &
> 3^rd
> >>   > prt_sc with the resulted network)
> >>   > Clearly, the majority of the network has faded away
> >>   > Awaiting your feedback, I would work on 2^nd suggestion
> >>   > Regards,
> >>   > Eyad
> >>   > *From:*pgrouting-users-bounces at lists.osgeo.org
> >>   > [mailto:pgrouting-users-bounces at lists.osgeo.org] *On Behalf Of
> >> *Daniel Kastl
> >>   > *Sent:* Thursday, December 18, 2014 6:28 AM
> >>   > *To:* pgRouting users mailing list
> >>   > *Subject:* Re: [pgrouting-users] Wierd results using
> pgr_kdijkstraPath
> >>   > Hi Eyad,
> >>   > It's difficult to give an answer based on your query and problem
> >>   > description only. I guess, that (still) your network topology is not
> >>   > correct. It looks like a data problem.
> >>   > There are 2 things you could do for now:
> >>   > (1) Show us some image of your "weird de-attached "little" pieces"
> >>   > (2) Try a simple shortest path query with one start and one end
> point
> >>   > and see if it works with pgr_dijkstra function for example.
> >>   > Daniel
> >>   > On Thu, Dec 18, 2014 at 7:37 AM, AUS - Eyad <b00038807 at aus.edu
> >>   > <mailto:b00038807 at aus.edu>> wrote:
> >>   > Hello pgr_Experts,
> >>   > I'm trying to get all the routes from a source point (i.e. 336) to a
> >>   > group of target/destination points (located at different edges/ends
> of
> >>   > linestrings' network) using the below code:
> >>   > SELECT seq, id1 as path, id2 as node, id3 as edge, (b.geom) as geom,
> >>   > cost FROM pgr_kdijkstraPath(
> >>   > 'SELECT id, source, target, (st_length(geom) * 0.001) as cost FROM
> >>   > 336, (SELECT array_agg(id) FROM schema.l1_pv1), false, false
> >>   > WHERE a.id1=b.id <http://b.id>
> >>   > It's resulting a weird de-attached "little" pieces of my original
> >>   > nodded_network! However, the number of resulted paths is equal to
> the
> >>   > target/destination points. Please advise:
> >>   > 1)What potential mistake I may have committed?
> >>   > 2)Does it mean that all the calculated travel_cost(s) are wrong (as
> > they
> >>   > are reflected/represented by wrong linestrings)?
> >>   > I'm using QGIS 2.4.0 and pgRouting pg93-binaries-2.4.0
> >>   > I found similar question on this list of pgRouting users, asked by
> >>   > Antonio last October
> (http://lists.osgeo.org/pipermail/pgrouting-users/2014-October/001992.html
> >>   > ), but obviously the question is not answered yet?
> >>   > Regards..
> >>   > Eyad
> >>   > _______________________________________________
> >>   > Pgrouting-users mailing list
> >>   > Pgrouting-users at lists.osgeo.org
> > <mailto:Pgrouting-users at lists.osgeo.org>
> >>   > http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> >>   > Georepublic UG & Georepublic Japan
> >>   > eMail: daniel.kastl at georepublic.de
> <mailto:daniel.kastl at georepublic.de>
> >>   > Web: http://georepublic.info
> >>   > No virus found in this message.
> >>   > Checked by AVG - www.avg.com <http://www.avg.com>
> >>   > Version: 2015.0.5577 / Virus Database: 4253/8755 - Release Date:
> > 12/17/14
> 12/17/14
> > Version: 2015.0.5577 / Virus Database: 4253/8755 - Release Date: 12/17/14
> Version: 2015.0.5577 / Virus Database: 4253/8761 - Release Date: 12/18/14
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20141219/ee4a2e81/attachment-0001.html>
More information about the Pgrouting-users mailing list
