[pgrouting-users] Large OD matrices
Manikanta Kondeti
mani.iiit123 at gmail.com
Tue Dec 23 02:14:09 PST 2014
Hello,
On Tue, Dec 23, 2014 at 2:25 PM, Hans Skov-Petersen <hsp at ign.ku.dk> wrote:
> Hi List,
> Being rather new at PgRouting (but not to network analysis in general), I
> am looking for means by which I efficiently can construct all pair,
> shortest path OD matrices for quite large networks (i.e. a graph of the
> road network of Denmark, 2.107.981 edges, 860.380 nodes).
> I am looking at the All Pairs Shortest Path, Johnson’s or Floyd-Warshall
> Algorithms.
> Questions:
> 1) Can anyone guide me to examples of the SQL syntax (or other code)
> involved in applying the algorithms
Load your data in postgresql database. Open psql terminal and select
the db and run the query like
" SELECT id , source, target, cost [,reverse_cost]
FROM edge_table
Refer to this tutorial:
http://workshop.pgrouting.org/chapters/shortest_path.html#multiple-shortest-paths-with-kdijkstra
> 2) Is there a way that the search (and output) can be simplified by
> limiting the search to only take OD within a given max-search-radius into
> account?
No idea, I cant help you here :/
> Cheers and Thanks
> Hans
- Manikanta
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20141223/c9c01247/attachment.html>
More information about the Pgrouting-users
