[pgrouting-users] osrm-tools has been updated
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Feb 22 23:11:43 PST 2014
On 2/22/2014 9:21 PM, Helder Alves wrote:
> Hi Steve,
> How are you doing? :-)
Prety good. I have been very busy lately so osrm-tools and pgrouting
work is suffering a little. But better to be busy than not :)
> Have you had any luck improving osrm-tools to generate valid TSP
> dmatrices usable on pgRouting?
Yes, this works very well. I have been able to generate 30x30 distance
matrix using a local OSRM instance by calling it from postgresql and it
only takes a few seconds.
I had some demos running but they are currently down as I had
osrm-routed setup to debug a problem that turned out to be bad data and
not software.
I need to re-sync the pgr2osrm tools to the current Project-OSRM master
as there have been some code changes. But it would fine for the using
the checkout that Ihave documented.
Best regards,
-Steve
> Helder Alves
> On Jan 28, 2014 4:35 PM, "Stephen Woodbridge" <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>> wrote:
> Hi all,
> For any of you that might be using my osrm-tools package at
> https://github.com/woodbri/__osrm-tools
> <https://github.com/woodbri/osrm-tools>
> I have pushed a bunch of changes over the last few days fixing
> issues that users have reported in pgr2osrm and added some new
> functions to the postgresql package.
> I strongly recommend that you upgrade to the current master branch
> and extract your data again.
> Thanks,
> -Steve
> _________________________________________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.__org
> <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
> <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
More information about the Pgrouting-users
