[pgrouting-users] osrm-tools has been updated
Helder Alves helderalvespt at gmail.com
Mon Feb 24 13:25:03 PST 2014
Thanks for the update, Steve.
I'll be waiting for the code re-sync... :-)
Helder Alves
On Sun, Feb 23, 2014 at 7:11 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 2/22/2014 9:21 PM, Helder Alves wrote:
>> Hi Steve,
>> How are you doing? :-)
> Prety good. I have been very busy lately so osrm-tools and pgrouting work
> is suffering a little. But better to be busy than not :)
>  Have you had any luck improving osrm-tools to generate valid TSP
>> dmatrices usable on pgRouting?
> Yes, this works very well. I have been able to generate 30x30 distance
> matrix using a local OSRM instance by calling it from postgresql and it
> only takes a few seconds.
> I had some demos running but they are currently down as I had osrm-routed
> setup to debug a problem that turned out to be bad data and not software.
> I need to re-sync the pgr2osrm tools to the current Project-OSRM master as
> there have been some code changes. But it would fine for the using the
> checkout that Ihave documented.
> Best regards,
>   -Steve
>> Helder Alves
>> On Jan 28, 2014 4:35 PM, "Stephen Woodbridge" <woodbri at swoodbridge.com
>> <mailto:woodbri at swoodbridge.com>> wrote:
>>     Hi all,
>>     For any of you that might be using my osrm-tools package at
>>     https://github.com/woodbri/__osrm-tools
>>     <https://github.com/woodbri/osrm-tools>
>>     I have pushed a bunch of changes over the last few days fixing
>>     issues that users have reported in pgr2osrm and added some new
>>     functions to the postgresql package.
>>     I strongly recommend that you upgrade to the current master branch
>>     and extract your data again.
>>     Thanks,
>>        -Steve
>>     _________________________________________________
>>     Pgrouting-users mailing list
>>     Pgrouting-users at lists.osgeo.__org
>>     <mailto:Pgrouting-users at lists.osgeo.org>
>>     http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
>>     <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140224/a7516003/attachment.html>
More information about the Pgrouting-users mailing list
