[pgrouting-users] pgr_apspjohnson algorithm
Helder Alves
helderalvespt at gmail.com
Sun Jan 5 10:18:04 PST 2014
Hi Steve,
I think I get it!
As soon I settle the reasoning in my head I'll contribute for the
project... :-)
Helder Alves
On Sun, Jan 5, 2014 at 1:18 PM, Stephen Woodbridge
<woodbri at swoodbridge.com>wrote:
> On 1/4/2014 11:28 PM, Helder Alves wrote:
>> Hi Steve,
>> I'm following those experiments you are working on... :-)
>> Regarding APSP I think currently it's not clear on what circumstances
>> these functions can be used. I found some explicit reference on
>> develop-vrp or gsoc-vrp branch and after that I realized no one seems to
>> be using those algorithms, apart from the fact that Johnson's
>> implementation seems to not handle at all negative costs which I think
>> that may defeat it theoretical purpose (but this is not the reason of
>> this e-mail as I'm still studying that subject).
> The two APSP algorithms were random additions from two of our GSoC
> students. I'm not sure what they are useful for, I'll need to go back to my
> graph theory and look that up again. I think that they have value where you
> construct a specific graph of important nodes and edges around a specific
> problem set and then you can solve that specific class of problems. I do
> not think it is useful to load a huge street network and solve it with APSP.
> Graph theory supports an abstract model for solving a lot more problems
> than vehicle routing. While MOST of our user base is focused on vehicle
> routing not everyone is so some of the tools we offer are more to support
> general graph solutions than just vehicle routing solutions.
> Maybe this help to understand my doubts...
> Understood. We are always looking and hoping to get support from the
> community. My skills are more generally focused on C development and
> process management rather than on the specifics of implementing any given
> graph solution. So pull requests are welcome. These could be for code,
> tests, and/or docs. I also enjoy a good discussion (like this) with our
> users. It is hard to know what is important to add to the product with such
> a discussion around limits and short comings and concerns that users have.
> Best regards,
> -Steve
> Thanks!
>> Helder Alves
>> On Jan 5, 2014 2:54 AM, "Stephen Woodbridge" <woodbri at swoodbridge.com
>> <mailto:woodbri at swoodbridge.com>> wrote:
>> On 1/4/2014 8:58 PM, Helder Alves wrote:
>> Hi List,
>> I've search the Internet for an example of a practical appliance
>> of
>> pgr_apspjohnson function using OSM data.
>> If this algorithm is supposed to feed VRP using a VRP distance
>> table,
>> from the found documentation I suppose it must generate the
>> equivalent
>> to TSP distance matrix but in a record format pair by pair of
>> all the
>> vertices instead of the multi-dimensional array used by pgr_TSP,
>> please
>> correct me if I'm wrong.
>> Problem is, what data is supposed to feed pgr_apspjohnson?
>> source/target/cost ways (table) data for the vids I want to
>> order using
>> pgr_pointtovids function, for example? If not, I would like
>> someone to
>> elaborate a bit on this...
>> What about pgr_apspwarshall? Is it the same or not?
>> Thanks in advance for your help!
>> Helder,
>> I'm not sure that either of these are very useful as they in theory
>> generate ALL pairs for all nodes in the graph and VRP and TSP want a
>> matrix of some defined locations in the graph and not ALL locations
>> in the graph.
>> I had the same problem and my solution to this was to create
>> https://github.com/woodbri/__osrm-tools
>> <https://github.com/woodbri/osrm-tools>
>> which provides some postgresql wrapper functions that call to a
>> local instance of OSRM and creates the distances or tables needed to
>> feed into VRP or TSP. This is much faster than pgrouting path
>> generation, but does not allow for all the flexibility of pgRouting.
>> Also you have the added headache of setting up ORSM.
>> The other option that I created was to create a function
>> pgr_vidsToDMatrix()
>> This creates and array vetrex ids into a distance matrix.
>> https://github.com/pgRouting/__pgrouting/tree/develop/src/__
>> common/doc/convenience
>> <https://github.com/pgRouting/pgrouting/tree/develop/src/
>> common/doc/convenience>
>> -Steve
>> _________________________________________________
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.__org
>> <mailto:Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
>> <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140105/ada4531b/attachment-0001.html>
More information about the Pgrouting-users
