[pgrouting-users] pgr_apspjohnson algorithm
Helder Alves helderalvespt at gmail.com
Sun Jan 5 12:28:51 PST 2014
Hi Steve,
I'm already beyond that stage but thanks anyway! ;-)
Steve/Daniel,
Regarding my assumptions regarding pgr_apspjohnson, they seem to be wrong.
Can you please elaborate a little bit on exactly which data must be fed
into pgr_apspjohnson?
>From the pgRouting examples I read, it seems to return the equivalent to
the distance matrix used by pgr_TSP however I don't understand exactly
which part of a routable table must be queried in a viable way for an
algorithm to be able to infer which nodes have to be routed. Can you help
me with this one?
Thanks!
Helder Alves
On Sun, Jan 5, 2014 at 7:52 PM, Stephen Woodbridge
<woodbri at swoodbridge.com>wrote:
> On 1/5/2014 2:16 PM, Helder Alves wrote:
>> Hi Daniel,
>> Regarding pgr_apspjohnson, I came to the conclusion that SQL query
>> passed into pgr_apspjohnson must already return a shortest path distance
>> matrix including all the stop points we want to optimize. Am I getting
>> it right?
>> What I'm about to try now is to unnest the distance matrix generated for
>> pgr_TSP to feed pgr_apspjohnson...
> You might be able to use something like this to convert the distance
> matrix into a table:
> with dm as (
>   select '{{1,2,3,4,5},
>            {6,7,8,9,10},
>            {11,12,13,14,15},
>            {16,17,18,19,20},
>            {21,22,23,24,25}}'::int[] as dm
> select i, j, dm.dm[j][i]
>   from generate_series(1, 5) i,
>        generate_series(1, 5) j,
>        dm;
> -Steve
>  Problem was that from all my previous reading I thought that at some
>> point APSP Johnson would itself generate the routing graphs, what seems
>> not to be the case, if my understanding from the source code is right...
>> Meaning APSP Johnson only takes care of the total route minimum cost
>> (permutations) avoiding the problem of TSP with negative costs.
>> Please let me know if I made foolish assumptions! :-)
>> Helder Alves
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140105/00d40b78/attachment.html>
More information about the Pgrouting-users mailing list
