[pgrouting-users] pgr_apspjohnson algorithm
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Jan 5 11:52:19 PST 2014
On 1/5/2014 2:16 PM, Helder Alves wrote:
> Hi Daniel,
> Regarding pgr_apspjohnson, I came to the conclusion that SQL query
> passed into pgr_apspjohnson must already return a shortest path distance
> matrix including all the stop points we want to optimize. Am I getting
> it right?
> What I'm about to try now is to unnest the distance matrix generated for
> pgr_TSP to feed pgr_apspjohnson...
You might be able to use something like this to convert the distance
matrix into a table:
with dm as (
select '{{1,2,3,4,5},
{6,7,8,9,10},
{11,12,13,14,15},
{16,17,18,19,20},
{21,22,23,24,25}}'::int[] as dm
select i, j, dm.dm[j][i]
from generate_series(1, 5) i,
generate_series(1, 5) j,
dm;
-Steve
> Problem was that from all my previous reading I thought that at some
> point APSP Johnson would itself generate the routing graphs, what seems
> not to be the case, if my understanding from the source code is right...
> Meaning APSP Johnson only takes care of the total route minimum cost
> (permutations) avoiding the problem of TSP with negative costs.
> Please let me know if I made foolish assumptions! :-)
> Helder Alves
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
