[pgrouting-users] pgr_apspjohnson algorithm
Helder Alves helderalvespt at gmail.com
Mon Jan 6 18:06:17 PST 2014
Hi guys,
Just to let you know that Steve's fix proposal for persistent
pgr_onedepot() results didn't work out and after building pgrouting from
develop-vrp tree (btw, I had to make this change) I got precisely the same
problem I got with building from my tree.
Thanks for the help, though! :-)
Helder Alves
On Tue, Jan 7, 2014 at 1:44 AM, Helder Alves <helderalvespt at gmail.com>wrote:
> Hi Steve,
> Thanks for your feedback... I'm applying the suggested fix and I'll let
> you know if it doesn't work.
> Regarding pgr_vrponedepot I was able to also make it work however I
> guess I stumbled on several issues:
>   * Depot open/close time seems to not be obeyed;
>   * Traveltime also seems to not being considered between departure and
>     arrival time every time;
> One thing that may not be obvious is that times in pgr_vrponedepot are all
> zero based on the depot open time. So depot open time should always be zero
> and then are other time should be time units in the future from the open
> time
> I've checked these issues against Daniel's implementation on his blog post
> @ http://blog.georepublic.info/2013/pgrouting-preview-the-new-vrp-solver/and I got to the same conclusions, please check my notes below.
>    1. Open a browser window on
>    http://blog.georepublic.info/2013/pgrouting-preview-the-new-vrp-solver/URL
>    2. Hit the "Sample Data" buttons for Vehicles, Depot and Orders, click
>    "Start Scheduler" and when results are generated click "schedule view"
>    3. Open a second browser window on
>    4. Hit the "Sample Data" buttons for Vehicles, Depot and Orders and
>    change Depot to "0,0,300,465,0,139.7107020020485,37.671709126526395"
>    5. Click "Start Scheduler" and when results are generated click
>    "schedule view"
>    6. Compare both schedule views and please note that both a) traveltime
>    from/to depot as well as b) depot's open time is not being taken in
>    consideration for arrival/departure time and optimization
> Does my reasoning makes sense or I'm missing some detail here?
> Helder Alves
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140107/5626d28c/attachment.html>
More information about the Pgrouting-users mailing list
