[pgrouting-users] Newbie pgr_dijkstra performance question
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jan 24 08:21:28 PST 2014
On 1/24/2014 10:45 AM, Andrew Harfoot wrote:
> Hi there,
> I have been looking at pgrouting in the past week, and have a test
> installation using the following:
> Win7 64bit on an i7 processor with 8Gb RAM
> Postgres 9.2.4 64bit
> Postgis 2.0.3-2 64bit
> pgrouting 2.0 64bit
> My test dataset is the Ordnance Survey Meridian roads dataset for Great
> Britain which has ~1.2 million edges.
> I can successfully use the pgr_dijkstra function to generate routing,
> but the performance seems a little slow. My test route takes around 10
> seconds to return in pgAdminIII, and so my first question is whether
> this is about what I should be expecting. I am not pre-filtering the
> ways being passed to pgr_dijkstra using a bounding box or such like
You should definitely use the bbox filtering of the ways, otherwise you
are loading ALL ways for every query. The way pgrouting works is on each
query, it reads the ways, builds a graph and solves the graph to give
you your results. The smaller the graph and number of ways need the
faster it is.
> The second question is that whilst exploring the performance, I removed
> the indexes that pgr_createtopology had built on the source and target
> fields of the road data. To my surprise, this had no effect whatsoever
> on the performance of pgr_dijkstra, and after rebuilding them and
> looking at the index stats in pgAdminIII, this is reporting no usage of
> the indexes at all (I did rerun some routing queries after rebuilding
> the indexes!). Again, is this expected?
Those indexes are not used when computing a route, they are only used to
compute the topology and potentially during any post-processing you
might decide to do to analyze the resultant path.
> It seems to contradict the
> recommendation to build the indexes in the pgr workshop:
> http://workshop.pgrouting.org/chapters/topology.html#add-indices
Right, needed to compute the topology.
pgRouting is extremely flexible because we dynamically build the graph
so we can easily do things like change the runtime solutions based on
integrating traffic data, or eliminating edges in a disaster area, or
changing the vehicle type or road preferences, etc. This comes at the
cost of being the fastest possible solution.
If performance is more important than this flexibility, then you might
want to look at Project-OSRM and osrm-tools as an alternative or to
augment pgRouting.
Thanks,
-Steve
> Any thoughts appreciated,
> Cheers,
> Andy
More information about the Pgrouting-users
