[pgrouting-users] build pgRouting 1.05 DARP tree
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jun 3 13:25:26 PDT 2014
Hi Eduardo,
I have not tried to build the DARP branch ever, but the error you are
getting has something to do with CGAL and the driving distance code. I
think there was a cmake option to disable this. Maybe something like:
cmake -DWITH_DD=NO .
To get it to compile and work in pgRouting 2.x you would need to migrate
the code into the 2.x source tree and update the cmake files so it gets
included and tweak the SQL code. Basically make it follow the pattern
setup for the other code.
-Steve
On 6/3/2014 3:49 PM, Eduardo Kanegae wrote:
> hi there,
> I'm running PostGIS 2.0.4 on PostgreSQL 8.4.12 (CentOS 6.3) and I'm
> trying to build pgRouting 1.05 (the DARP branch) but it gives me the
> following error:
> [ 7%] Building C object extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp.o
> [ 14%] Building CXX object extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp_solver.o
> Linking CXX shared library ../../../lib/librouting_tsp.so
> [ 14%] Built target routing_tsp
> [ 21%] Building C object extra/darp/src/CMakeFiles/routing_darp.dir/darp.o
> [ 28%] Building CXX object
> extra/darp/src/CMakeFiles/routing_darp.dir/darp_solver.o
> Linking CXX shared library ../../../lib/librouting_darp.so
> [ 28%] Built target routing_darp
> Scanning dependencies of target routing_dd
> [ 35%] Building C object
> extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.o
> [ 42%] Building CXX object
> extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.o
> In file included from /usr/local/include/CGAL/internal/Exact_type_selector.h:39,
> from /usr/local/include/CGAL/Filtered_kernel.h:35,
> from
> /usr/local/src/pgrouting-1.05-darp/extra/driving_distance/src/alpha_drivedist.cpp:35:
> /usr/local/include/CGAL/Mpzf.h: In function âCGAL::Mpzf
> CGAL::Mpzf_square(const CGAL::Mpzf&)â:
> /usr/local/include/CGAL/Mpzf.h:709: error: âmpn_sqrâ was not declared
> in this scope
> make[2]: ** [extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.o]
> Erro 1
> make[1]: ** [extra/driving_distance/src/CMakeFiles/routing_dd.dir/all] Erro 2
> make: ** [all] Erro 2
> Here's my "ccmake" config params:
> Boost_DIR /usr/lib64/boost
> Boost_INCLUDE_DIR /usr/include
> Boost_LIBRARY_DIRS /usr/lib
> CGAL_INCLUDE_DIR /usr/local/include
> CGAL_LIBRARIES /usr/local/lib/libCGAL.so
> CMAKE_AR /usr/bin/ar
> CMAKE_BACKWARDS_COMPATIBILITY 2.4
> CMAKE_BUILD_TYPE
> CMAKE_COLOR_MAKEFILE ON
> CMAKE_CXX_COMPILER /usr/bin/c++
> CMAKE_CXX_FLAGS
> CMAKE_CXX_FLAGS_DEBUG -g
> CMAKE_CXX_FLAGS_MINSIZEREL -Os -DNDEBUG
> CMAKE_CXX_FLAGS_RELEASE -O3 -DNDEBUG
> CMAKE_CXX_FLAGS_RELWITHDEBINFO -O2 -g
> CMAKE_C_COMPILER /usr/bin/gcc
> CMAKE_C_FLAGS
> CMAKE_C_FLAGS_DEBUG -g
> CMAKE_C_FLAGS_MINSIZEREL -Os -DNDEBUG
> CMAKE_C_FLAGS_RELEASE -O3 -DNDEBUG
> CMAKE_C_FLAGS_RELWITHDEBINFO -O2 -g
> CMAKE_EXE_LINKER_FLAGS
> CMAKE_EXE_LINKER_FLAGS_DEBUG
> CMAKE_EXE_LINKER_FLAGS_MINSIZE
> CMAKE_EXE_LINKER_FLAGS_RELEASE
> CMAKE_EXE_LINKER_FLAGS_RELWITH
> CMAKE_EXPORT_COMPILE_COMMANDS OFF
> CMAKE_INSTALL_PREFIX /usr/local
> CMAKE_LINKER /usr/bin/ld
> CMAKE_MAKE_PROGRAM /usr/bin/gmake
> CMAKE_MODULE_LINKER_FLAGS
> CMAKE_MODULE_LINKER_FLAGS_DEBU
> CMAKE_MODULE_LINKER_FLAGS_MINS
> CMAKE_MODULE_LINKER_FLAGS_RELE
> CMAKE_MODULE_LINKER_FLAGS_RELW
> CMAKE_NM /usr/bin/nm
> CMAKE_OBJCOPY /usr/bin/objcopy
> CMAKE_OBJDUMP /usr/bin/objdump
> CMAKE_RANLIB /usr/bin/ranlib
> CMAKE_SHARED_LINKER_FLAGS
> CMAKE_SHARED_LINKER_FLAGS_DEBU
> CMAKE_SHARED_LINKER_FLAGS_MINS
> CMAKE_SHARED_LINKER_FLAGS_RELE
> CMAKE_SHARED_LINKER_FLAGS_RELW
> CMAKE_SKIP_INSTALL_RPATH OFF
> CMAKE_SKIP_RPATH OFF
> CMAKE_STRIP /usr/bin/strip
> CMAKE_USE_RELATIVE_PATHS OFF
> CMAKE_VERBOSE_MAKEFILE OFF
> EXECUTABLE_OUTPUT_PATH
> GAUL_INCLUDE_DIR /usr/local/include
> GAUL_LIBRARIES /usr/local/lib/libgaul.so
> GAUL_UTIL_LIBRARIES /usr/local/lib/libgaul_util.so
> LIBRARY_OUTPUT_PATH /usr/lib64/pgsql
> PGROUTING_CORE_INCLUDE_DIR /usr/local/src/pgrouting-1.05-darp/core/src
> POSTGRESQL_EXECUTABLE /usr/bin/postgres
> POSTGRESQL_INCLUDE_DIR /usr/include/pgsql/server
> POSTGRESQL_LIBRARIES /usr/lib64/pgsql
> WITH_CGAL ON
> WITH_DARP ON
> WITH_DD ON
> WITH_GAUL ON
> WITH_PostgreSQL ON
> WITH_TSP ON
> As far as I know DARP module is only available at this 1.05 darp
> branch. Or should I try to build pgRouting 2 + PostGIS 2.1.3 +
> PostgreSQL 9.x ?
> ps.:
> a) CGAL installed is 4.4
> b) GAUL installed is version 0.1849
> thanks for any help.
> Eduardo Patto Kanegae
> http://www.webmapit.com | @webmapit
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
