[pgrouting-users] build pgRouting 1.05 DARP tree
Eduardo Kanegae
eduardo.kanegae at gmail.com
Tue Jun 3 14:04:28 PDT 2014
thanks Steve,
I've turned off CGAL and DD options withing ccmake but now it seems
like some kind of declaration errors:
[ 12%] Building C object extra/darp/src/CMakeFiles/routing_darp.dir/darp.o
In file included from
/usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c:22:
/usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.h:43: error:
expected specifier-qualifier-list before âIntervalâ
/usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c: In function
âfetch_distanceâ:
/usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c:369: error:
âorder_tâ has no member named âtoâ
For this case I think this branch could attend me, because it's a
specific application which I'll need only DARP functions and will not
use the other routing solvers.
Eduardo
2014-06-03 17:25 GMT-03:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
> Hi Eduardo,
> I have not tried to build the DARP branch ever, but the error you are
> getting has something to do with CGAL and the driving distance code. I think
> there was a cmake option to disable this. Maybe something like:
> cmake -DWITH_DD=NO .
> To get it to compile and work in pgRouting 2.x you would need to migrate the
> code into the 2.x source tree and update the cmake files so it gets included
> and tweak the SQL code. Basically make it follow the pattern setup for the
> other code.
> -Steve
> On 6/3/2014 3:49 PM, Eduardo Kanegae wrote:
>> hi there,
>> I'm running PostGIS 2.0.4 on PostgreSQL 8.4.12 (CentOS 6.3) and I'm
>> trying to build pgRouting 1.05 (the DARP branch) but it gives me the
>> following error:
>> [ 7%] Building C object extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp.o
>> [ 14%] Building CXX object
>> extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp_solver.o
>> Linking CXX shared library ../../../lib/librouting_tsp.so
>> [ 14%] Built target routing_tsp
>> [ 21%] Building C object extra/darp/src/CMakeFiles/routing_darp.dir/darp.o
>> [ 28%] Building CXX object
>> extra/darp/src/CMakeFiles/routing_darp.dir/darp_solver.o
>> Linking CXX shared library ../../../lib/librouting_darp.so
>> [ 28%] Built target routing_darp
>> Scanning dependencies of target routing_dd
>> [ 35%] Building C object
>> extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.o
>> [ 42%] Building CXX object
>> extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.o
>> /usr/local/include/CGAL/internal/Exact_type_selector.h:39,
>> from /usr/local/include/CGAL/Filtered_kernel.h:35,
>> from
>> /usr/local/src/pgrouting-1.05-darp/extra/driving_distance/src/alpha_drivedist.cpp:35:
>> /usr/local/include/CGAL/Mpzf.h: In function âCGAL::Mpzf
>> CGAL::Mpzf_square(const CGAL::Mpzf&)â:
>> /usr/local/include/CGAL/Mpzf.h:709: error: âmpn_sqrâ was not declared
>> in this scope
>> make[2]: **
>> [extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.o]
>> Erro 1
>> make[1]: ** [extra/driving_distance/src/CMakeFiles/routing_dd.dir/all]
>> Erro 2
>> make: ** [all] Erro 2
>> Here's my "ccmake" config params:
>> Boost_DIR /usr/lib64/boost
>> Boost_INCLUDE_DIR /usr/include
>> Boost_LIBRARY_DIRS /usr/lib
>> CGAL_INCLUDE_DIR /usr/local/include
>> CGAL_LIBRARIES /usr/local/lib/libCGAL.so
>> CMAKE_AR /usr/bin/ar
>> CMAKE_BACKWARDS_COMPATIBILITY 2.4
>> CMAKE_BUILD_TYPE
>> CMAKE_COLOR_MAKEFILE ON
>> CMAKE_CXX_COMPILER /usr/bin/c++
>> CMAKE_CXX_FLAGS
>> CMAKE_CXX_FLAGS_DEBUG -g
>> CMAKE_CXX_FLAGS_MINSIZEREL -Os -DNDEBUG
>> CMAKE_CXX_FLAGS_RELEASE -O3 -DNDEBUG
>> CMAKE_CXX_FLAGS_RELWITHDEBINFO -O2 -g
>> CMAKE_C_COMPILER /usr/bin/gcc
>> CMAKE_C_FLAGS
>> CMAKE_C_FLAGS_DEBUG -g
>> CMAKE_C_FLAGS_MINSIZEREL -Os -DNDEBUG
>> CMAKE_C_FLAGS_RELEASE -O3 -DNDEBUG
>> CMAKE_C_FLAGS_RELWITHDEBINFO -O2 -g
>> CMAKE_EXE_LINKER_FLAGS
>> CMAKE_EXE_LINKER_FLAGS_DEBUG
>> CMAKE_EXE_LINKER_FLAGS_MINSIZE
>> CMAKE_EXE_LINKER_FLAGS_RELEASE
>> CMAKE_EXE_LINKER_FLAGS_RELWITH
>> CMAKE_EXPORT_COMPILE_COMMANDS OFF
>> CMAKE_INSTALL_PREFIX /usr/local
>> CMAKE_LINKER /usr/bin/ld
>> CMAKE_MAKE_PROGRAM /usr/bin/gmake
>> CMAKE_MODULE_LINKER_FLAGS
>> CMAKE_MODULE_LINKER_FLAGS_DEBU
>> CMAKE_MODULE_LINKER_FLAGS_MINS
>> CMAKE_MODULE_LINKER_FLAGS_RELE
>> CMAKE_MODULE_LINKER_FLAGS_RELW
>> CMAKE_NM /usr/bin/nm
>> CMAKE_OBJCOPY /usr/bin/objcopy
>> CMAKE_OBJDUMP /usr/bin/objdump
>> CMAKE_RANLIB /usr/bin/ranlib
>> CMAKE_SHARED_LINKER_FLAGS
>> CMAKE_SHARED_LINKER_FLAGS_DEBU
>> CMAKE_SHARED_LINKER_FLAGS_MINS
>> CMAKE_SHARED_LINKER_FLAGS_RELE
>> CMAKE_SHARED_LINKER_FLAGS_RELW
>> CMAKE_SKIP_INSTALL_RPATH OFF
>> CMAKE_SKIP_RPATH OFF
>> CMAKE_STRIP /usr/bin/strip
>> CMAKE_USE_RELATIVE_PATHS OFF
>> CMAKE_VERBOSE_MAKEFILE OFF
>> EXECUTABLE_OUTPUT_PATH
>> GAUL_INCLUDE_DIR /usr/local/include
>> GAUL_LIBRARIES /usr/local/lib/libgaul.so
>> GAUL_UTIL_LIBRARIES /usr/local/lib/libgaul_util.so
>> LIBRARY_OUTPUT_PATH /usr/lib64/pgsql
>> PGROUTING_CORE_INCLUDE_DIR
>> /usr/local/src/pgrouting-1.05-darp/core/src
>> POSTGRESQL_EXECUTABLE /usr/bin/postgres
>> POSTGRESQL_INCLUDE_DIR /usr/include/pgsql/server
>> POSTGRESQL_LIBRARIES /usr/lib64/pgsql
>> WITH_CGAL ON
>> WITH_DARP ON
>> WITH_DD ON
>> WITH_GAUL ON
>> WITH_PostgreSQL ON
>> WITH_TSP ON
>> As far as I know DARP module is only available at this 1.05 darp
>> branch. Or should I try to build pgRouting 2 + PostGIS 2.1.3 +
>> PostgreSQL 9.x ?
>> ps.:
>> a) CGAL installed is 4.4
>> b) GAUL installed is version 0.1849
>> thanks for any help.
>> Eduardo Patto Kanegae
>> http://www.webmapit.com | @webmapit
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
