[pgrouting-users] build pgRouting 1.05 DARP tree
Eduardo Kanegae eduardo.kanegae at gmail.com
Wed Jun 4 12:52:14 PDT 2014
hi, just to keep records,
I found the latest error origin: (
/usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.h:43 )
- compiler was not finding $include/postgresql/server/datatype/timestamp.h
Now I'm trying to resolve some new errors:
[ 37%] Building CXX object core/src/CMakeFiles/routing.dir/boost_wrapper.o
In file included from /usr/local/include/boost/graph/adjacency_list.hpp:247,
                 from
/usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp:25:
/usr/include/boost/graph/detail/adjacency_list.hpp:2795: error: âhashâ
is not a template
/usr/include/boost/graph/detail/adjacency_list.hpp:2796: error:
explicit specialization of non-template â__gnu_cxx::hashâ
/usr/include/boost/graph/detail/adjacency_list.hpp:2803: error: âhashâ
is not a template
â__gnu_cxx::hashâ is not a template type
/usr/include/boost/graph/detail/adjacency_list.hpp:2813: error: âhashâ
is not a template
/usr/include/boost/graph/detail/adjacency_list.hpp:2823: error: âhashâ
is not a template
/usr/include/boost/graph/detail/adjacency_list.hpp: In instantiation
of âboost::detail::adj_list_any_edge_pmap::bind_<boost::adjacency_list<boost::listS,
boost::vecS, boost::directedS, boost::no_property, Vertex,
boost::no_property, boost::listS>, Vertex, boost::edge_weight_t>â:
/usr/include/boost/graph/detail/adjacency_list.hpp:2736:
instantiated from
âboost::detail::adj_list_choose_edge_pmap<boost::edge_weight_t,
boost::adjacency_list<boost::listS, boost::vecS, boost::directedS,
boost::no_property, Vertex, boost::no_property, boost::listS>,
Vertex>â
/usr/include/boost/graph/detail/adjacency_list.hpp:2743:
instantiated from
âboost::detail::adj_list_edge_property_selector::bind_<boost::adjacency_list<boost::listS,
/usr/local/include/boost/graph/properties.hpp:215:   instantiated from
âboost::detail::edge_property_map<boost::adjacency_list<boost::listS,
boost::no_property, boost::listS>, boost::edge_weight_t>â
/usr/local/include/boost/graph/properties.hpp:233:   instantiated from
âboost::property_map<boost::adjacency_list<boost::listS, boost::vecS,
boost::directedS, boost::no_property, Vertex, boost::no_property,
boost::listS>, boost::edge_weight_t, void>â
/usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp:76:
instantiated from here
/usr/include/boost/graph/detail/adjacency_list.hpp:2701: error:
forming reference to void
/usr/include/boost/graph/detail/adjacency_list.hpp:2702: error:
/usr/include/boost/graph/detail/adjacency_list.hpp:2706: error:
/usr/include/boost/graph/detail/adjacency_list.hpp:2709: error:
/usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp: In
function âint boost_dijkstra(edge_t*, unsigned int, int, int, bool,
bool, path_element_t**, int*, char**)â:
error: no matching function for call to âget(boost::edge_weight_t,
boost_dijkstra(edge_t*, unsigned int, int, int, bool, bool,
path_element_t**, int*, char**)::graph_t&)â
                 from
/usr/include/boost/graph/detail/adjacency_list.hpp: In function
âtypename boost::property_map<typename Config::graph_type, Property,
void>::type boost::get(Property, boost::adj_list_helper<Config,
Base>&) [with Config =
boost::detail::adj_list_gen<boost::adjacency_list<boost::listS,
boost::no_property, boost::listS>, boost::vecS, boost::listS,
boost::listS>::config, Base =
boost::directed_graph_helper<boost::detail::adj_list_gen<boost::adjacency_list<boost::listS,
boost::listS>::config>, Property = float8 Vertex::*]â:
/usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp:123:
/usr/include/boost/graph/detail/adjacency_list.hpp:1724: error:
invalid use of void expression
make[2]: ** [core/src/CMakeFiles/routing.dir/boost_wrapper.o] Erro 1
make[1]: ** [core/src/CMakeFiles/routing.dir/all] Erro 2
make: ** [all] Erro 2
Eduardo
2014-06-03 18:04 GMT-03:00 Eduardo Kanegae <eduardo.kanegae at gmail.com>:
> thanks Steve,
> I've turned off CGAL and DD options withing ccmake but now it seems
> like some kind of declaration errors:
> [ 12%] Building C object extra/darp/src/CMakeFiles/routing_darp.dir/darp.o
> /usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c:22:
> /usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.h:43: error:
> expected specifier-qualifier-list before âIntervalâ
> /usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c: In function
> âfetch_distanceâ:
> /usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c:369: error:
> âorder_tâ has no member named âtoâ
> For this case I think this branch could attend me, because it's a
> specific application which I'll need only DARP functions and will not
> use the other routing solvers.
> Eduardo
> 2014-06-03 17:25 GMT-03:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
>> Hi Eduardo,
>> I have not tried to build the DARP branch ever, but the error you are
>> getting has something to do with CGAL and the driving distance code. I think
>> there was a cmake option to disable this. Maybe something like:
>> cmake -DWITH_DD=NO .
>> To get it to compile and work in pgRouting 2.x you would need to migrate the
>> code into the 2.x source tree and update the cmake files so it gets included
>> and tweak the SQL code. Basically make it follow the pattern setup for the
>> other code.
>> -Steve
>> On 6/3/2014 3:49 PM, Eduardo Kanegae wrote:
>>> hi there,
>>> I'm running PostGIS 2.0.4 on PostgreSQL 8.4.12 (CentOS 6.3) and I'm
>>> trying to build pgRouting 1.05 (the DARP branch) but it gives me the
>>> following error:
>>> [  7%] Building C object extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp.o
>>> [ 14%] Building CXX object
>>> extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp_solver.o
>>> Linking CXX shared library ../../../lib/librouting_tsp.so
>>> [ 14%] Built target routing_tsp
>>> [ 21%] Building C object extra/darp/src/CMakeFiles/routing_darp.dir/darp.o
>>> [ 28%] Building CXX object
>>> extra/darp/src/CMakeFiles/routing_darp.dir/darp_solver.o
>>> Linking CXX shared library ../../../lib/librouting_darp.so
>>> [ 28%] Built target routing_darp
>>> Scanning dependencies of target routing_dd
>>> [ 35%] Building C object
>>> extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.o
>>> [ 42%] Building CXX object
>>> extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.o
>>> /usr/local/include/CGAL/internal/Exact_type_selector.h:39,
>>>                   from /usr/local/include/CGAL/Filtered_kernel.h:35,
>>>                   from
>>> /usr/local/src/pgrouting-1.05-darp/extra/driving_distance/src/alpha_drivedist.cpp:35:
>>> /usr/local/include/CGAL/Mpzf.h: In function âCGAL::Mpzf
>>> CGAL::Mpzf_square(const CGAL::Mpzf&)â:
>>> /usr/local/include/CGAL/Mpzf.h:709: error: âmpn_sqrâ was not declared
>>> in this scope
>>> make[2]: **
>>> [extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.o]
>>> Erro 1
>>> make[1]: ** [extra/driving_distance/src/CMakeFiles/routing_dd.dir/all]
>>> Erro 2
>>> Here's my "ccmake" config params:
>>> Boost_DIR                        /usr/lib64/boost
>>> Boost_INCLUDE_DIR                /usr/include
>>> Boost_LIBRARY_DIRS               /usr/lib
>>> CGAL_INCLUDE_DIR                 /usr/local/include
>>> CGAL_LIBRARIES                   /usr/local/lib/libCGAL.so
>>> CMAKE_AR                         /usr/bin/ar
>>> CMAKE_BACKWARDS_COMPATIBILITY    2.4
>>> CMAKE_BUILD_TYPE
>>> CMAKE_COLOR_MAKEFILE             ON
>>> CMAKE_CXX_COMPILER               /usr/bin/c++
>>> CMAKE_CXX_FLAGS
>>> CMAKE_CXX_FLAGS_DEBUG            -g
>>> CMAKE_CXX_FLAGS_MINSIZEREL       -Os -DNDEBUG
>>> CMAKE_CXX_FLAGS_RELEASE          -O3 -DNDEBUG
>>> CMAKE_CXX_FLAGS_RELWITHDEBINFO   -O2 -g
>>> CMAKE_C_COMPILER                 /usr/bin/gcc
>>> CMAKE_C_FLAGS
>>> CMAKE_C_FLAGS_DEBUG              -g
>>> CMAKE_C_FLAGS_MINSIZEREL         -Os -DNDEBUG
>>> CMAKE_C_FLAGS_RELEASE            -O3 -DNDEBUG
>>> CMAKE_C_FLAGS_RELWITHDEBINFO     -O2 -g
>>> CMAKE_EXE_LINKER_FLAGS
>>> CMAKE_EXE_LINKER_FLAGS_DEBUG
>>> CMAKE_EXE_LINKER_FLAGS_MINSIZE
>>> CMAKE_EXE_LINKER_FLAGS_RELEASE
>>> CMAKE_EXE_LINKER_FLAGS_RELWITH
>>> CMAKE_EXPORT_COMPILE_COMMANDS    OFF
>>> CMAKE_INSTALL_PREFIX             /usr/local
>>> CMAKE_LINKER                     /usr/bin/ld
>>> CMAKE_MAKE_PROGRAM               /usr/bin/gmake
>>> CMAKE_MODULE_LINKER_FLAGS
>>> CMAKE_MODULE_LINKER_FLAGS_DEBU
>>> CMAKE_MODULE_LINKER_FLAGS_MINS
>>> CMAKE_MODULE_LINKER_FLAGS_RELE
>>> CMAKE_MODULE_LINKER_FLAGS_RELW
>>> CMAKE_NM                         /usr/bin/nm
>>> CMAKE_OBJCOPY                    /usr/bin/objcopy
>>> CMAKE_OBJDUMP                    /usr/bin/objdump
>>> CMAKE_RANLIB                     /usr/bin/ranlib
>>> CMAKE_SHARED_LINKER_FLAGS
>>> CMAKE_SHARED_LINKER_FLAGS_DEBU
>>> CMAKE_SHARED_LINKER_FLAGS_MINS
>>> CMAKE_SHARED_LINKER_FLAGS_RELE
>>> CMAKE_SHARED_LINKER_FLAGS_RELW
>>> CMAKE_SKIP_INSTALL_RPATH         OFF
>>> CMAKE_SKIP_RPATH                 OFF
>>> CMAKE_STRIP                      /usr/bin/strip
>>> CMAKE_USE_RELATIVE_PATHS         OFF
>>> CMAKE_VERBOSE_MAKEFILE           OFF
>>> EXECUTABLE_OUTPUT_PATH
>>> GAUL_INCLUDE_DIR                 /usr/local/include
>>> GAUL_LIBRARIES                   /usr/local/lib/libgaul.so
>>> GAUL_UTIL_LIBRARIES              /usr/local/lib/libgaul_util.so
>>> LIBRARY_OUTPUT_PATH              /usr/lib64/pgsql
>>> PGROUTING_CORE_INCLUDE_DIR
>>> POSTGRESQL_EXECUTABLE            /usr/bin/postgres
>>> POSTGRESQL_INCLUDE_DIR           /usr/include/pgsql/server
>>> POSTGRESQL_LIBRARIES             /usr/lib64/pgsql
>>> WITH_CGAL                        ON
>>> WITH_DARP                        ON
>>> WITH_DD                          ON
>>> WITH_GAUL                        ON
>>> WITH_PostgreSQL                  ON
>>> WITH_TSP                         ON
>>> As far as I know DARP module is only available at this 1.05 darp
>>> branch. Or should I try to build pgRouting 2 + PostGIS 2.1.3 +
>>> PostgreSQL 9.x ?
>>> ps.:
>>> a) CGAL installed is 4.4
>>> b) GAUL installed is version 0.1849
>>> thanks for any help.
>>> Eduardo Patto Kanegae
>>> http://www.webmapit.com | @webmapit
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
