[pgrouting-users] build pgRouting 1.05 DARP tree
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jun 4 13:09:42 PDT 2014
Hi Eduardo,
Good to see you making some progress on this.
So the current error is Boost related. What version of Boost are you
using. But this might be a problem that the code is using:
namespace std {
or just:
namespace std;
You might need to change the code so all occurances of
hash get changed to std::hash
This could be true for other std::* functions.
-Steve
On 6/4/2014 3:52 PM, Eduardo Kanegae wrote:
> hi, just to keep records,
> I found the latest error origin: (
> /usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.h:43 )
> - compiler was not finding $include/postgresql/server/datatype/timestamp.h
> Now I'm trying to resolve some new errors:
> [ 37%] Building CXX object core/src/CMakeFiles/routing.dir/boost_wrapper.o
> In file included from /usr/local/include/boost/graph/adjacency_list.hpp:247,
> from
> /usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp:25:
> /usr/include/boost/graph/detail/adjacency_list.hpp:2795: error: âhashâ
> is not a template
> /usr/include/boost/graph/detail/adjacency_list.hpp:2796: error:
> explicit specialization of non-template â__gnu_cxx::hashâ
> /usr/include/boost/graph/detail/adjacency_list.hpp:2803: error: âhashâ
> is not a template
> â__gnu_cxx::hashâ is not a template type
> /usr/include/boost/graph/detail/adjacency_list.hpp:2813: error: âhashâ
> is not a template
> /usr/include/boost/graph/detail/adjacency_list.hpp:2823: error: âhashâ
> is not a template
> /usr/include/boost/graph/detail/adjacency_list.hpp: In instantiation
> of âboost::detail::adj_list_any_edge_pmap::bind_<boost::adjacency_list<boost::listS,
> boost::vecS, boost::directedS, boost::no_property, Vertex,
> boost::no_property, boost::listS>, Vertex, boost::edge_weight_t>â:
> /usr/include/boost/graph/detail/adjacency_list.hpp:2736:
> instantiated from
> âboost::detail::adj_list_choose_edge_pmap<boost::edge_weight_t,
> boost::adjacency_list<boost::listS, boost::vecS, boost::directedS,
> boost::no_property, Vertex, boost::no_property, boost::listS>,
> Vertex>â
> /usr/include/boost/graph/detail/adjacency_list.hpp:2743:
> instantiated from
> âboost::detail::adj_list_edge_property_selector::bind_<boost::adjacency_list<boost::listS,
> /usr/local/include/boost/graph/properties.hpp:215: instantiated from
> âboost::detail::edge_property_map<boost::adjacency_list<boost::listS,
> boost::no_property, boost::listS>, boost::edge_weight_t>â
> /usr/local/include/boost/graph/properties.hpp:233: instantiated from
> âboost::property_map<boost::adjacency_list<boost::listS, boost::vecS,
> boost::directedS, boost::no_property, Vertex, boost::no_property,
> boost::listS>, boost::edge_weight_t, void>â
> /usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp:76:
> instantiated from here
> /usr/include/boost/graph/detail/adjacency_list.hpp:2701: error:
> forming reference to void
> /usr/include/boost/graph/detail/adjacency_list.hpp:2702: error:
> /usr/include/boost/graph/detail/adjacency_list.hpp:2706: error:
> /usr/include/boost/graph/detail/adjacency_list.hpp:2709: error:
> /usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp: In
> function âint boost_dijkstra(edge_t*, unsigned int, int, int, bool,
> bool, path_element_t**, int*, char**)â:
> error: no matching function for call to âget(boost::edge_weight_t,
> boost_dijkstra(edge_t*, unsigned int, int, int, bool, bool,
> path_element_t**, int*, char**)::graph_t&)â
> from
> /usr/include/boost/graph/detail/adjacency_list.hpp: In function
> âtypename boost::property_map<typename Config::graph_type, Property,
> void>::type boost::get(Property, boost::adj_list_helper<Config,
> Base>&) [with Config =
> boost::detail::adj_list_gen<boost::adjacency_list<boost::listS,
> boost::no_property, boost::listS>, boost::vecS, boost::listS,
> boost::listS>::config, Base =
> boost::directed_graph_helper<boost::detail::adj_list_gen<boost::adjacency_list<boost::listS,
> boost::listS>::config>, Property = float8 Vertex::*]â:
> /usr/local/src/pgrouting-1.05-darp/core/src/boost_wrapper.cpp:123:
> /usr/include/boost/graph/detail/adjacency_list.hpp:1724: error:
> invalid use of void expression
> make[2]: ** [core/src/CMakeFiles/routing.dir/boost_wrapper.o] Erro 1
> make[1]: ** [core/src/CMakeFiles/routing.dir/all] Erro 2
> make: ** [all] Erro 2
> Eduardo
> 2014-06-03 18:04 GMT-03:00 Eduardo Kanegae <eduardo.kanegae at gmail.com>:
>> thanks Steve,
>> I've turned off CGAL and DD options withing ccmake but now it seems
>> like some kind of declaration errors:
>> [ 12%] Building C object extra/darp/src/CMakeFiles/routing_darp.dir/darp.o
>> /usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c:22:
>> /usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.h:43: error:
>> expected specifier-qualifier-list before âIntervalâ
>> /usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c: In function
>> âfetch_distanceâ:
>> /usr/local/src/pgrouting-1.05-darp/extra/darp/src/darp.c:369: error:
>> âorder_tâ has no member named âtoâ
>> For this case I think this branch could attend me, because it's a
>> specific application which I'll need only DARP functions and will not
>> use the other routing solvers.
>> Eduardo
>> 2014-06-03 17:25 GMT-03:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
>>> Hi Eduardo,
>>> I have not tried to build the DARP branch ever, but the error you are
>>> getting has something to do with CGAL and the driving distance code. I think
>>> there was a cmake option to disable this. Maybe something like:
>>> cmake -DWITH_DD=NO .
>>> To get it to compile and work in pgRouting 2.x you would need to migrate the
>>> code into the 2.x source tree and update the cmake files so it gets included
>>> and tweak the SQL code. Basically make it follow the pattern setup for the
>>> other code.
>>> -Steve
>>> On 6/3/2014 3:49 PM, Eduardo Kanegae wrote:
>>>> hi there,
>>>> I'm running PostGIS 2.0.4 on PostgreSQL 8.4.12 (CentOS 6.3) and I'm
>>>> trying to build pgRouting 1.05 (the DARP branch) but it gives me the
>>>> following error:
>>>> [ 7%] Building C object extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp.o
>>>> [ 14%] Building CXX object
>>>> extra/tsp/src/CMakeFiles/routing_tsp.dir/tsp_solver.o
>>>> Linking CXX shared library ../../../lib/librouting_tsp.so
>>>> [ 14%] Built target routing_tsp
>>>> [ 21%] Building C object extra/darp/src/CMakeFiles/routing_darp.dir/darp.o
>>>> [ 28%] Building CXX object
>>>> extra/darp/src/CMakeFiles/routing_darp.dir/darp_solver.o
>>>> Linking CXX shared library ../../../lib/librouting_darp.so
>>>> [ 28%] Built target routing_darp
>>>> Scanning dependencies of target routing_dd
>>>> [ 35%] Building C object
>>>> extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha.o
>>>> [ 42%] Building CXX object
>>>> extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.o
>>>> /usr/local/include/CGAL/internal/Exact_type_selector.h:39,
>>>> from /usr/local/include/CGAL/Filtered_kernel.h:35,
>>>> from
>>>> /usr/local/src/pgrouting-1.05-darp/extra/driving_distance/src/alpha_drivedist.cpp:35:
>>>> /usr/local/include/CGAL/Mpzf.h: In function âCGAL::Mpzf
>>>> CGAL::Mpzf_square(const CGAL::Mpzf&)â:
>>>> /usr/local/include/CGAL/Mpzf.h:709: error: âmpn_sqrâ was not declared
>>>> in this scope
>>>> make[2]: **
>>>> [extra/driving_distance/src/CMakeFiles/routing_dd.dir/alpha_drivedist.o]
>>>> Erro 1
>>>> make[1]: ** [extra/driving_distance/src/CMakeFiles/routing_dd.dir/all]
>>>> Erro 2
>>>> Here's my "ccmake" config params:
>>>> Boost_DIR /usr/lib64/boost
>>>> Boost_INCLUDE_DIR /usr/include
>>>> Boost_LIBRARY_DIRS /usr/lib
>>>> CGAL_INCLUDE_DIR /usr/local/include
>>>> CGAL_LIBRARIES /usr/local/lib/libCGAL.so
>>>> CMAKE_AR /usr/bin/ar
>>>> CMAKE_BACKWARDS_COMPATIBILITY 2.4
>>>> CMAKE_BUILD_TYPE
>>>> CMAKE_COLOR_MAKEFILE ON
>>>> CMAKE_CXX_COMPILER /usr/bin/c++
>>>> CMAKE_CXX_FLAGS
>>>> CMAKE_CXX_FLAGS_DEBUG -g
>>>> CMAKE_CXX_FLAGS_MINSIZEREL -Os -DNDEBUG
>>>> CMAKE_CXX_FLAGS_RELEASE -O3 -DNDEBUG
>>>> CMAKE_CXX_FLAGS_RELWITHDEBINFO -O2 -g
>>>> CMAKE_C_COMPILER /usr/bin/gcc
>>>> CMAKE_C_FLAGS
>>>> CMAKE_C_FLAGS_DEBUG -g
>>>> CMAKE_C_FLAGS_MINSIZEREL -Os -DNDEBUG
>>>> CMAKE_C_FLAGS_RELEASE -O3 -DNDEBUG
>>>> CMAKE_C_FLAGS_RELWITHDEBINFO -O2 -g
>>>> CMAKE_EXE_LINKER_FLAGS
>>>> CMAKE_EXE_LINKER_FLAGS_DEBUG
>>>> CMAKE_EXE_LINKER_FLAGS_MINSIZE
>>>> CMAKE_EXE_LINKER_FLAGS_RELEASE
>>>> CMAKE_EXE_LINKER_FLAGS_RELWITH
>>>> CMAKE_EXPORT_COMPILE_COMMANDS OFF
>>>> CMAKE_INSTALL_PREFIX /usr/local
>>>> CMAKE_LINKER /usr/bin/ld
>>>> CMAKE_MAKE_PROGRAM /usr/bin/gmake
>>>> CMAKE_MODULE_LINKER_FLAGS
>>>> CMAKE_MODULE_LINKER_FLAGS_DEBU
>>>> CMAKE_MODULE_LINKER_FLAGS_MINS
>>>> CMAKE_MODULE_LINKER_FLAGS_RELE
>>>> CMAKE_MODULE_LINKER_FLAGS_RELW
>>>> CMAKE_NM /usr/bin/nm
>>>> CMAKE_OBJCOPY /usr/bin/objcopy
>>>> CMAKE_OBJDUMP /usr/bin/objdump
>>>> CMAKE_RANLIB /usr/bin/ranlib
>>>> CMAKE_SHARED_LINKER_FLAGS
>>>> CMAKE_SHARED_LINKER_FLAGS_DEBU
>>>> CMAKE_SHARED_LINKER_FLAGS_MINS
>>>> CMAKE_SHARED_LINKER_FLAGS_RELE
>>>> CMAKE_SHARED_LINKER_FLAGS_RELW
>>>> CMAKE_SKIP_INSTALL_RPATH OFF
>>>> CMAKE_SKIP_RPATH OFF
>>>> CMAKE_STRIP /usr/bin/strip
>>>> CMAKE_USE_RELATIVE_PATHS OFF
>>>> CMAKE_VERBOSE_MAKEFILE OFF
>>>> EXECUTABLE_OUTPUT_PATH
>>>> GAUL_INCLUDE_DIR /usr/local/include
>>>> GAUL_LIBRARIES /usr/local/lib/libgaul.so
>>>> GAUL_UTIL_LIBRARIES /usr/local/lib/libgaul_util.so
>>>> LIBRARY_OUTPUT_PATH /usr/lib64/pgsql
>>>> PGROUTING_CORE_INCLUDE_DIR
>>>> POSTGRESQL_EXECUTABLE /usr/bin/postgres
>>>> POSTGRESQL_INCLUDE_DIR /usr/include/pgsql/server
>>>> POSTGRESQL_LIBRARIES /usr/lib64/pgsql
>>>> WITH_CGAL ON
>>>> WITH_DARP ON
>>>> WITH_DD ON
>>>> WITH_GAUL ON
>>>> WITH_PostgreSQL ON
>>>> WITH_TSP ON
>>>> As far as I know DARP module is only available at this 1.05 darp
>>>> branch. Or should I try to build pgRouting 2 + PostGIS 2.1.3 +
>>>> PostgreSQL 9.x ?
>>>> ps.:
>>>> a) CGAL installed is 4.4
>>>> b) GAUL installed is version 0.1849
>>>> thanks for any help.
>>>> Eduardo Patto Kanegae
>>>> http://www.webmapit.com | @webmapit
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
