[pgrouting-users] TRSP returns "Start id was not found"
Vladimir fl_v at inbox.ru
Thu Mar 6 10:47:17 PST 2014
Hello All!
I try to use TRSP with source_edge/target_edge syntax:
SELECT seq, id1 AS node, id2 AS edge, cost FROM pgr_trsp('SELECT id,source::integer,target::integer,cost::float FROM edge_tab', 138, 0.5, 161, 0.5, false, false);
but the error "Start id was not found" occurs.
Edges with ids 138 and 161 exists in edge_tab that's checked by
SELECT * FROM edge_tab WHERE id in (138,161)
pgr_version: 2.0.0,pgrouting-2.0.0,0,f26831f,master,1.53.0
Please could you tell me what's wrong ?
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140306/37b4467e/attachment.html>
More information about the Pgrouting-users mailing list
