[pgrouting-users] (SOLVED) TRSP returns "Start id was not found"
Vladimir fl_v at inbox.ru
Fri Mar 7 02:45:07 PST 2014
 Hi again.
As written in the  documentation  for SQL statement of TRSP:
id:    int4 identifier of the edge
But  pgr_createTopology function creates new "noded" table with "id" of bigint type.
I've solved this problem by casting "id" to integer type.
Now that's works:
SELECT seq, id1 AS node, id2 AS edge, cost FROM pgr_trsp('SELECT id::integer,source::integer,target::integer,cost::float FROM edge_tab', 138, 0.5, 161, 0.5, false, false);
Thanks very much to author of  this post for idea.
Best regards.
>Hello All!
>I try to use TRSP with source_edge/target_edge syntax:
>SELECT seq, id1 AS node, id2 AS edge, cost FROM pgr_trsp('SELECT id,source::integer,target::integer,cost::float FROM edge_tab', 138, 0.5, 161, 0.5, false, false);
>but the error "Start id was not found" occurs.
>Edges with ids 138 and 161 exists in edge_tab that's checked by
>SELECT * FROM edge_tab WHERE id in (138,161)
>pgr_version: 2.0.0,pgrouting-2.0.0,0,f26831f,master,1.53.0
>Please could you tell me what's wrong ?
>_______________________________________________
>Pgrouting-users mailing list
>Pgrouting-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140307/1aa8cf4d/attachment.html>
More information about the Pgrouting-users mailing list
