[pgrouting-users] Calculating the shortest way between pairs
Daniel Kastl
daniel at georepublic.de
Fri Mar 14 07:33:06 PDT 2014
On Fri, Mar 14, 2014 at 11:26 PM, Carsten Hogertz <carsten.hogertz at gmail.com
> wrote:
> Maybe to clearify.
> I've got the following two tables:
> Table at_2po_4pgr with the columns:
> id integer NOT NULL,
> osm_id bigint,
> osm_name character varying,
> osm_meta character varying,
> osm_source_id bigint,
> osm_target_id bigint,
> clazz integer,
> flags integer,
> source integer,
> target integer,
> km double precision,
> kmh integer,
> cost2 double precision,
> reverse_cost double precision,
> x1 double precision,
> y1 double precision,
> x2 double precision,
> y2 double precision,
> geom_way geometry(LineString,4326)
> and Table routing_pair with the columns:
> id integer,
> h_key integer,
> lat_htl double precision,
> lon_htl double precision,
> source integer,
> geom_htl geometry(Point,4326),
> lat_bhf double precision,
> lon_bhf double precision,
> target integer,
> geom_bhf geometry(Point,4326)
> The routing_pair table hold three important information:
> ID
> SOURCE
> TARGET
> All columns are filled (source + target are calculated from at_2po_4pgr.
> The task seems to be quite simple: I want for each row from the
> routing_pair the distance between soure + target (and if possible its geom).
> Could you please help me how to solve this?
Hi Carsten,
There is a function named kDijkstra and it allows you to calculate all
paths from one node to many:
http://docs.pgrouting.org/2.0/en/src/kdijkstra/doc/index.html#pgr-kdijkstra
If something is not clear with the page above, feel free to ask.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140314/32803502/attachment.html>
More information about the Pgrouting-users
