[pgrouting-users] Calculating the shortest way between pairs
Carsten Hogertz carsten.hogertz at gmail.com
Fri Mar 14 08:00:17 PDT 2014
lol. Now we're talking about the same issue!
I could run n x n queries but this would not be very efficient as I'd like
to have a more "automatic" solution.
I already thought about function and looping but as being a complete newbie
on looping and writing functions this seems quite hard to solve for myself.
Maybe you've got a hint?
thanks
carsten
2014-03-14 15:53 GMT+01:00 Daniel Kastl <daniel at georepublic.de>:
> On Fri, Mar 14, 2014 at 11:42 PM, Carsten Hogertz <
> carsten.hogertz at gmail.com> wrote:
>> Hi Daniel,
>> thanks for your eMail.
>> Well, I think it's not a 1-n calculation. IMHO it's a 1-1
>> calculation,right?
>> So I don't know how to calculate the distance for each row of the
>> routing_pair table.
> Well, you need to run this query for each row. So with n rows you need n
> queries.
> If you use standard shortest path function you need to run "n x n" queries.
> You may want to write a custom function, which makes first a select of all
> records in your table and then loops through these records.
> Or don't I still understand the problem?
> Daniel
>> Thanks
>> Carsten
>> 2014-03-14 15:33 GMT+01:00 Daniel Kastl <daniel at georepublic.de>:
>>> On Fri, Mar 14, 2014 at 11:26 PM, Carsten Hogertz <
>>>> Maybe to clearify.
>>>> I've got the following two tables:
>>>> Table at_2po_4pgr with the columns:
>>>>   id integer NOT NULL,
>>>>   osm_id bigint,
>>>>   osm_name character varying,
>>>>   osm_meta character varying,
>>>>   osm_source_id bigint,
>>>>   osm_target_id bigint,
>>>>   clazz integer,
>>>>   flags integer,
>>>>   source integer,
>>>>   target integer,
>>>>   km double precision,
>>>>   kmh integer,
>>>>   cost2 double precision,
>>>>   reverse_cost double precision,
>>>>   x1 double precision,
>>>>   y1 double precision,
>>>>   x2 double precision,
>>>>   y2 double precision,
>>>>   geom_way geometry(LineString,4326)
>>>> and Table routing_pair with the columns:
>>>>   id integer,
>>>>   h_key integer,
>>>>   lat_htl double precision,
>>>>   lon_htl double precision,
>>>>   source integer,
>>>>   geom_htl geometry(Point,4326),
>>>>   lat_bhf double precision,
>>>>   lon_bhf double precision,
>>>>   target integer,
>>>>   geom_bhf geometry(Point,4326)
>>>> The routing_pair table hold three important information:
>>>> ID
>>>> SOURCE
>>>> TARGET
>>>> All columns are filled (source + target are calculated from at_2po_4pgr.
>>>> The task seems to be quite simple: I want for each row from the
>>>> routing_pair the distance between soure + target (and if possible its geom).
>>>> Could you please help me how to solve this?
>>> Hi Carsten,
>>> There is a function named kDijkstra and it allows you to calculate all
>>> paths from one node to many:
>>> http://docs.pgrouting.org/2.0/en/src/kdijkstra/doc/index.html#pgr-kdijkstra
>>> If something is not clear with the page above, feel free to ask.
>>> Daniel
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de
>>> Web: http://georepublic.info
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140314/a3543ff3/attachment.html>
More information about the Pgrouting-users mailing list
