[pgrouting-users] Isochronous
Daniel Kastl daniel at georepublic.de
Tue Mar 18 10:45:10 PDT 2014
On Wed, Mar 19, 2014 at 2:32 AM, Valeria Muñoz <valemunoz at gmail.com> wrote:
> HI
> I need to develop a system to generate isochrones according to minutes,
> you can make this with postgis and how?
> Valeria
Hi Valeria,
The function "pgr_drivingDistance" returns all nodes that can be reached
from a start point within a certain "cost" (ie. time) and it also returns
the time need to get to each of these nodes:
http://docs.pgrouting.org/2.0/en/src/driving_distance/doc/dd_driving_distance.html#pgr-driving-distance
The function "pgr_pointsAsPolygon" then returns a polygon that includes a
set of points:
http://docs.pgrouting.org/2.0/en/src/driving_distance/doc/dd_points_as_polygon.html#pgr-points-as-polygon
The argument is a SQL statement, so if you need isochrones you could run it
for each isoline.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140319/93303c38/attachment.html>
More information about the Pgrouting-users mailing list
