[pgrouting-users] Isochronous
Valeria Muñoz
valemunoz at gmail.com
Wed Mar 19 06:06:10 PDT 2014
thanks!!!
2014-03-18 21:29 GMT-04:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
> Hi Ian,
> Can you add a reference to your project here:
> https://github.com/pgRouting/pgrouting/wiki/Writing-functions
> under the Friends of pgRouting section.
> Thanks,
> -Steve
> On 3/18/2014 9:05 PM, Ian Tangert wrote:
>> Also there is a query at https://github.com/GregersP/networkReach that
>> will do that (return edges based on nodes reached) and cover parts of
>> segments when the cost distance goes beyond a node without reaching
>> another node. It's based on pgr_drivingDistance() as mentioned. You
>> might not need such a level of detail but it's worth a look and I'm
>> always looking for ways to improve on it if you have any suggestions.
>> -ian
>> On Tue, Mar 18, 2014 at 1:45 PM, Daniel Kastl <daniel at georepublic.de
>> <mailto:daniel at georepublic.de>> wrote:
>> On Wed, Mar 19, 2014 at 2:32 AM, Valeria Muñoz <valemunoz at gmail.com
>> <mailto:valemunoz at gmail.com>> wrote:
>> HI
>> I need to develop a system to generate isochrones according to
>> minutes, you can make this with postgis and how?
>> Valeria
>> Hi Valeria,
>> The function "pgr_drivingDistance" returns all nodes that can be
>> reached from a start point within a certain "cost" (ie. time) and it
>> also returns the time need to get to each of these nodes:
>> http://docs.pgrouting.org/2.0/en/src/driving_distance/doc/
>> dd_driving_distance.html#pgr-driving-distance
>> The function "pgr_pointsAsPolygon" then returns a polygon that
>> includes a set of points:
>> dd_points_as_polygon.html#pgr-points-as-polygon
>> The argument is a SQL statement, so if you need isochrones you could
>> run it for each isoline.
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl@
>> georepublic.de>
>> Web: http://georepublic.info
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.
>> osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140319/9ef17eb8/attachment.html>
More information about the Pgrouting-users
