[pgrouting-users] Help needed for installing PgRouting with Postgres App on Mac Pro
Yan Qian
qianyanseu at gmail.com
Mon Oct 20 19:11:45 PDT 2014
I think the brew installation under /Cellar/postgresql is fine. The `psql`
and `createdb` under /usr/local/bin are just *symbolic links* created by
homebrew during the installation. (See, when you use psql, the default
extension directory is under Cellar/postgresql, so at least the postgresql
installation is running properly.)
Since the terminal prompts that `postgis.control` is missing, you'll need
to check why those files are not found in the directory where they're
supposed to be (in your case,
/usr/local/Cellar/postgresql/9.3.5_1/share/postgresql/extensions/).
If you're not sure, maybe reinstalling postgis would help, use `brew
uninstall postgis` then `brew install postgis`.
If the problems still exists, try copy the extension control file to the
expected directories manually.
PostGIS and pgRouting are just extensions. If your PostgreSQL works fine,
you are not far away from success.
On Tue, Oct 21, 2014 at 9:23 AM, Danqing Zhang <danqing0703 at berkeley.edu>
wrote:
> I tried 'which psql' and they are shown as below:
> danqing0703 at Danqings-MacBook-Pro:~$ which psql
> /usr/local/bin/psql
> danqing0703 at Danqings-MacBook-Pro:~$ which createdb
> /usr/local/bin/createdb
> but in the /usr/local/Cellar/postgresql/9.3.5_1/share/postgresql/bin
> folder, there are also createdb,psql etc...I am really confused and stuck
> on this step. Thanks for the help!
> [image: Inline image 1]
> On Mon, Oct 20, 2014 at 6:18 PM, Danqing Zhang <danqing0703 at berkeley.edu>
> wrote:
>> Hi All
>> I have the same problem again with postgis using homebrew:
>> I successfully installed postgresql,and installed postgis(just 'brew
>> install postgis'), then I created a database and typed pgsql, I tried to
>> create extension postgis but failed, the output is as below:
>> I encountered this problem previously and this caused me to use
>> Postgres.app....could anyone give me some link to solve this for I searched
>> online and could not get the reasonable solution, many thanks!
>> On Mon, Oct 20, 2014 at 9:45 AM, Thomas Cioppettini <tom at tecrails.com>
>> wrote:
>>> http://postgresapp.com/documentation/install.html
>>> On Oct 20, 2014, at 12:43 PM, Danqing Zhang <danqing0703 at berkeley.edu>
>>> wrote:
>>> Hi everyone
>>> Thanks for the help!!
>>> I also tried to install all things via
>>> http://boundlessgeo.com/solutions/opengeo-suite/
>>> I think my problem is that I tried to install PgRouting from too many
>>> sources, but I cannot get everything uninstalled completely. I previously
>>> even cannot get PostGIS working.
>>> Can anyone give me some hints on how to *uninstall Postgres App
>>> completely* from Mac, for I think simply move to trash does not work,
>>> for it changed some environment variable I think. Many thanks for the help
>>> again!
>>> Best, Danqing
>>> On Mon, Oct 20, 2014 at 9:30 AM, Yan Qian <qianyanseu at gmail.com> wrote:
>>>> Hi! I recently installed pgrouting via homebrew on OS X Yosemite
>>>> (10.10) and everything worked. What I mean by 'via homebrew' is that all
>>>> the dependencies are also installed from homebrew, including PostgreSQL and
>>>> PostGIS.
>>>> I suggest uninstalling the Postgres App that you already have on your
>>>> system and try installing merely througn homebrew recipes.
>>>> Good luck!
>>>> On Tue, Oct 21, 2014 at 12:26 AM, Thomas Cioppettini <tom at tecrails.com>
>>>> wrote:
>>>>> Hey, I wrote the recipe for installing PgRouting through homebrew.
>>>>> Can you reply with a gist of the output you receive? I will see if I can
>>>>> resolve any issues after I am done with work this evening.
>>>>> -Tom
>>>>> On Oct 20, 2014, at 12:23 PM, Danqing Zhang <danqing0703 at berkeley.edu>
>>>>> wrote:
>>>>> Hi everyone
>>>>> I am a graduate student from Berkeley doing research on taxi
>>>>> trajectory, and I am in great need of PgRouting. However, I tried all
>>>>> methods and could not get PgRouting installed.
>>>>> I installed PostgreSQL and PostGIS using Postgres App(
>>>>> http://postgresapp.com/), and tried the following ways to install
>>>>> PgRouting but all failed:
>>>>> - This website:http://www.kyngchaos.com/software/postgres
>>>>> <http://www.google.com/url?q=http%3A%2F%2Fwww.kyngchaos.com%2Fsoftware%2Fpostgres&sa=D&sntz=1&usg=AFQjCNFq6h3OydMSJyBpwol-5vh93jT7Wg>
>>>>> - homebrew
>>>>> - macports
>>>>> Can anyone provide me with some useful links so that I can learn from
>>>>> them and install PgRouting on my Mac? Many thanks for the help!
>>>>> Best, Danqing
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>> yours, sincerely
>>>> *Yan Qian*
>>>> Dept. of GIS
>>>> Southeast University
yours, sincerely
*Yan Qian*
Dept. of GIS
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20141021/bd2c6399/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20141021/bd2c6399/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20141021/bd2c6399/attachment-0003.png>
More information about the Pgrouting-users
