[pgrouting-users] pgr Create Topology question
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Sep 30 20:05:32 PDT 2014
Hello John,
Vicky has developed a new version of create topology that supports
incremental build of the topology.
https://github.com/cvvergara/pgrouting/tree/commonFunctions
This will get merged into pgrouting at some point, but it would be great
if you wanted to give it a try and report if you have problems. We have
done some basic testing but it sounds like you have a great test case
for this.
You can clone her repository and build pgrouting from that source and
then you should have access to those new functions. Vicky is on the list
so if you need help or run into issues, give a shout and let us know how
it goes.
Since you are on windows, it might be easier to just take the plpgsql
code from her source and install it without trying to build everything.
-Steve
On 9/30/2014 5:20 PM, John Zabrenski wrote:
> Hello everyone,
> I have a question about pgr_createTopology...
> I am attempting to make a routable US street network table using
> pgRouting (pgRouting ver 2.0.0, postGIS 2.1.1, postgresql 9.2).
> It is running on localhost (32 bit windows, 4 gb RAM).
> I have a postgres table created originally from street shapefiles that
> now has about 43 million rows.
> As I expected, the create topology function faced an out of memory error
> about halfway through the creation, and gave me this message:
> My original statement:
> SELECT pgr_createTopology('usa_streets', 0.00001, 'geom', 'gid');
> Result:
> NOTICE: out of memory
> NOTICE: UPDATE public.usa_streets SET source = 22148149,target =
> 22152619 WHERE gid = 9166028
> Total query runtime: 96149189 ms.
> 1 row retrieved.
> The resulting vertices_pgr table has only about 22 million rows and I
> get errors for null sources when trying to run routing functions.
> Would it be possible to run another Create Topology for rows in the
> original edges table where source and target are null, or will this just
> create two conflicting networks?
> I am curious if anyone here is familiar or experienced with a workaround
> for this problem? Or is the only solution more RAM? If I'm leaving out
> any relevant information please let me know.
> Thank you for reading,
> John Zabrenski
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
