[pgrouting-users] Routing via different Layers/Levels
AUS - Eyad b00038807 at aus.edu
Mon Jan 5 12:57:20 PST 2015
Hi All,
Is there a way to conduct nodding for part of a network instead of the whole
network in order to restrict routing through specific channels (i.e. 2
layers network where access is restricted via ramps)?
I tried the below 2 codes:
1)      select pgr_nodeNetwork('schema.network_table',50,'id','geom') FROM
schema.network_table where (Layer='first_level');
2)      select pgr_nodeNetwork('schema.network_table' where
(Layer='first_level'),50,'id','geom');
The first is entering endless loop processing the data; the second is
returning a syntax Error (@WHERE)!
I know that the second sounds clearly wrong code, but I provided the above
example trying to brain-storm with all.
If there is no option to do the required while nodding or creating_topology,
is it possible to utilize 2 separately_noded networks (instead of the below
highlighted one) within the following code?
SELECT seq, id1 as source, id2 as target, cost FROM pgr_kdijkstraCost(
    'SELECT id, source, target, (st_length(geom) * 0.001) as cost FROM
schema.network_table_noded',
    (SELECT id FROM schema.p_table WHERE id=1), (SELECT array_agg(id) FROM
schema.p_table), false, false
Please advise suitable/potential code..
Happy New Year to ALL
Eyad
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150106/3c6aa58d/attachment.html>
More information about the Pgrouting-users mailing list
