[pgrouting-users] Isochrones as polygons
Simon Georget
simon.georget at gmail.com
Fri May 15 07:38:55 PDT 2015
Hi Ross,
Thanks for your reply,
I've tried, indeed, to increase the distance with no success. I get the
same error. That sounds strange.
Of course, I read Anita Graser blog posts but on her examples she calculate
isochrones points by points. I want to automatize the task, that's why I
want to use a function.
I had no time last days to work on that. I'll try next week.
Do you you if 'pgr_pointsAsPolygon' relies on 'pgr_alphashape' function. I
got a strange error message when trying to implement it directly ?
bye, simo
On Thu, May 14, 2015 at 12:11 PM, McDonaldR <McDonaldR at angus.gov.uk> wrote:
> Hello Simon
> Have you tried increasing your distance to 10000? The error message says
> your distance is too short and not enough points are available to create
> the alphashape.
> As an aside:
> Look at this post:
> http://anitagraser.com/2011/09/25/a-closer-look-at-alpha-shapes-in-pgrouting/
> And maybe at this post:
> http://anitagraser.com/2013/07/07/public-transport-isochrones-with-pgrouting/
> That should help you create the polygons from driving distance.
> Ross
> *From:* pgrouting-users-bounces at lists.osgeo.org [
> mailto:pgrouting-users-bounces at lists.osgeo.org
> <pgrouting-users-bounces at lists.osgeo.org>] *On Behalf Of *Simon Georget
> *Sent:* 13 May 2015 18:48
> *To:* pgrouting-users at lists.osgeo.org
> *Subject:* [pgrouting-users] Isochrones as polygons
> Hi list,
> I'm trying to generate isochrones as polygons in the way it is explained
> in that post :
> https://smathermather.wordpress.com/2014/08/06/drivetime-analyses-pgrouting/
> I'm not familiar with postgres/postgis and I get a bit confused when
> trying to understand the difference between pgr_alphashape() /
> pgr_pointsAsPolygon(). I've read a lot through the web but did not find lot
> of examples scirpts.
> I'm able to generate the drivingDistance() but I get lost when trying to
> get points to generate my polygons.
> Is there any sample script somewhere combining the use of
> pgr_drivingDistance() with pgr_pointsAsPolygon() ?
> Here is an attempt to adapt the script from smathermather with my data.
> Note that I want to run it on multiple start points :
> CREATE OR REPLACE FUNCTION nn_search (geom geometry) RETURNS
> int8 AS $$
> SELECT id FROM roads_idf_l93_vertices_pgr AS r
> ORDER BY geom <#> r.the_geom
> LIMIT 1;
> $$ LANGUAGE SQL VOLATILE;
> -- cette fonction renvoie un polygone
> -- elle prend en paramètre l'id du noeud et le cost
> CREATE OR REPLACE FUNCTION alpha_shape (id integer, cost integer) RETURNS
> geometry AS $$
> WITH alphashape AS(SELECT pgr_alphaShape('WITH
> DD AS (
> SELECT seq, id1 AS node, cost
> FROM pgr_drivingDistance(''SELECT id, source::int4 AS source,
> target::int4 AS target, length::float8 AS cost FROM roads_idf_l93'',' || id
> || ', ' || cost || ', false, false)
> points AS (
> SELECT v.id::int4 AS id, x::float8, y::float8
> FROM roads_idf_l93_vertices_pgr v, DD d
> WHERE v.id = d.node)
> SELECT * FROM points')),
> alphapoints AS (
> SELECT ST_Makepoint((pgr_alphashape).x, (pgr_alphashape).y) FROM
> alphashape),
> alphaline AS (
> SELECT ST_MakeLine(ST_MakePoint) FROM alphapoints)
> SELECT ST_MakePolygon(ST_AddPoint(ST_MakeLine,
> ST_StartPoint(ST_MakeLine))) AS the_geom FROM alphaline
> CREATE TABLE alpha_test AS
> WITH dest_ids AS (
> SELECT nn_search(geom) AS id FROM gare_idf_l93
> -- cost 1000 m
> SELECT alpha_shape(id::int, 1000)::geometry, id FROM dest_ids;
> Executing this script return the following error :
> ERROR: Distance is too short. only 2 vertices for alpha shape
> calculation. alpha shape calculation needs at least 3 vertices.
> CONTEXT: SQL function "alpha_shape" statement 1
> ********** Erreur **********
> ERROR: Distance is too short. only 2 vertices for alpha shape calculation.
> État SQL :XX000
> Contexte : SQL function "alpha_shape" statement 1
> Any help would be appreciated. Thanks
> simo
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails
> may be monitored for security and network management reasons. Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient
> system or data on it by this message or any attachment.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150515/503d52de/attachment.html>
More information about the Pgrouting-users
