[pgrouting-users] Isochrones as polygons
Simon Georget simon.georget at gmail.com
Mon May 18 09:11:51 PDT 2015
Indeed, my data presents some lines with less that 3 vertices, see the
screenshot below :
I will probably use python to make all my tests in order to generate
polygons when possible. - since I'm not confortable enough with postgresql
to handle that.
I guess it is possible to adapt the query (in first post) to test if at
least 3 vertices are there.
Or maybe I could adapt the nn_search() function to be sure the closest
vertice is connected to others.
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150518/0a816672/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150518/0a816672/attachment-0001.png>
More information about the Pgrouting-users mailing list
