[pgrouting-users] PGR_DIJKSTRA execution time
Omar Fernando Pessôa
omar.pessoa at gmail.com
Thu Aug 11 11:42:29 PDT 2016
Hi guys.
I am using OSM to generate my road postgis database (south of Brazil).
My vertex table has 1282959 rows.
To decrease time to run PGR_DIJKSTRA I have make a box from my
"destinations" position. Decreasing it to 18264 rows in a materialized view
with indexes.
Then running PGR_DIJKSTRA, with k x k (k = 100+- vertex). The running time
of PGR_DIJKSTRA is something about 30s.
This is a good "time"? Can I do it better?
*drop materialized view if exists view_vertex;*
*create materialized view view_vertex as((select id, the_geom,
vel_med,source, target, cost, reverse_cost from vertex_ruas where the_geom
&& 'POLYGON((-49.3954855 -27.0998678,-49.3954855 -26.6055895,-48.7818607
-26.6055895,-48.7818607 -27.0998678,-49.3954855 -27.0998678))'::geometry
and status <> 1) UNION ALL(select id, the_geom, vel_med,source, target,
cost, reverse_cost from vertex_ruas_aux where the_geom &&
and status <> 1)); *
*CREATE UNIQUE INDEX idx_id_view_vertex ON view_vertex(id);*
*CREATE INDEX idx_source_view_vertex ON view_vertex(source);*
*CREATE INDEX idx_target_view_vertex ON view_vertex(target);*
*insert into trajetos select id, ids, idt, st_length(the_geom::geography)
as distancia , sequencia, sequencia_vertex, the_geom, vel_med from(SELECT
start_vid || '-' || end_vid as id,start_vid as ids, end_vid as idt,
array_to_string(array_agg(edge),',') as sequencia,
array_to_string(array_agg(node),',') as
sequencia_vertex,ST_LineMerge(st_collect(the_geom)) as the_geom,
avg(vel_med) as vel_med FROM pgr_dijkstra( 'SELECT id, source, target,
cost, reverse_cost FROM view_vertex' ,
array[3922267,3922268,3922269,3922270,3922271,3922272,3922273,3922274,3922275,3922276,3922277,3922278,3922279,2667391,3922280,3922281,3922282,3922283,3922284,3922285,3922286,3922287,3922288,3922289,3922290,3922291,3922292,3922293,3922294,3922295,3922296,3922297,3922298,3922299,3922300,3922301,3922302,3922303,3922304,3922305,3922306,3922307,3922308,3922309,3922310,3922311,3922312,3922313,3922314,3922315,3922316,3922317,3922318,3922319,3922320,3922321,3922322,3922323,3922324,3922325,3922326,3922327,3922328,3922329,3922330,3922331,3922332,3922333,3922334,3922335,3922336,3922337,3922338,3922339,3922340,3922341,3922342,3922343,3922344,3922345,3922346,3922347,3922348,3922349,3922350,3922351,3922352,3922353,3922354,3922355,3922356,3922357,3922358,3922359,3922360,3922361,3922362,3922363,3922364,3922365,3922366,3922367,3922368,3922369,3922370],
true)join view_vertex t on t.id <http://t.id> = edge group by start_vid,
end_vid order by start_vid, end_vid)a;*
This is my way to do this. (example).
Thanks guys! Waiting for withpoints to make me happy. This *vertex_ruas_aux
*table is a helper table to create new vertex using *ST_LineLocatePoint *from
*vertex_ruas, *status is set to 1 to make this invalid, generating 2 new
linestrings *vertex_ruas_aux*.
*Omar Fernando Pessôa*
http://www.opessoa.com
Desenvolvedor de Sistemas / Systems Software Developer
C++ / PHP / C# / Javascript
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160811/46224065/attachment.html>
More information about the Pgrouting-users
