[pgrouting-users] PGR_DIJKSTRA execution time
    Vicky Vergara
    vicky at georepublic.de
    Thu Aug 11 15:37:30 PDT 2016
Hello Omar,
I don't have your data (not intending to have it) so, lets go by steps:
First of all the code looks quite "crowded", so I took the liberty of
formatting it a little, see at the bottom.
If its a matter of analysis, lets start with using
\timing
so after each command you get the time it took to do things
The insert clause is doing many things:
   -  has a JOIN that takes time,
   -  has this ST_LineMerge(st_collect(the_geom) that also consume time
   - has this array_to_string(array_agg(edge),',') that also consume time
   - has the call to pgr_dijkstra that also consumes time, etc.
if you want to time how long it takes to make the pgr_dijkstra just do:
SELECT * FROM pgr_dijkstra('SELECT id, source, target, cost, reverse_cost
FROM view_vertex',
array[3922267,3922268,3922269,3922270,3922271,3922272,3922273,3922274,3922275,3922276,3922277,3922278,
3922279,2667391,3922280,3922281,3922282,3922283,3922284,3922285,3922286,3922287,3922288,3922289,
3922290,3922291,3922292,3922293,3922294,3922295,3922296,3922297,3922298,3922299,3922300,3922301,
3922302,3922303,3922304,3922305,3922306,3922307,3922308,3922309,3922310,3922311,3922312,3922313,
3922314,3922315,3922316,3922317,3922318,3922319,3922320,3922321,3922322,3922323,3922324,3922325,
3922326,3922327,3922328,3922329,3922330,3922331,3922332,3922333,3922334,3922335,3922336,3922337,
3922338,3922339,3922340,3922341,3922342,3922343,3922344,3922345,3922346,3922347,3922348,3922349,
3922350,3922351,3922352,3922353,3922354,3922355,3922356,3922357,3922358,3922359,3922360,3922361,
3922362,3922363,3922364,3922365,3922366,3922367,3922368,3922369,3922370],
        , true);
you can save the results in a temporary table:
select * INTO dijkstra_results FROM pgr_dijkstra(......);
-- do the insert clause using dijkstra_results
drop table dijkstra_results
Hope I was of help.
Vicky
/* a little formatting */
DROP materialized view if exists view_vertex;
CREATE materialized view view_vertex as (
    (select id, the_geom, vel_med,source, target, cost, reverse_cost
        from vertex_ruas
        where the_geom && 'POLYGON((-49.3954855 -27.0998678,-49.3954855
-26.6055895,-48.7818607 -26.6055895,-48.7818607 -27.0998678,-49.3954855
-27.0998678))'::geometry and status <> 1)
        UNION ALL
        from vertex_ruas_aux
-27.0998678))'::geometry and status <> 1));
CREATE UNIQUE INDEX idx_id_view_vertex ON view_vertex(id);
CREATE INDEX idx_source_view_vertex ON view_vertex(source);
CREATE INDEX idx_target_view_vertex ON view_vertex(target);
insert into trajetos
  select id, ids, idt, st_length(the_geom::geography) as distancia ,
sequencia, sequencia_vertex, the_geom, vel_med
  from (
    SELECT start_vid || '-' || end_vid as id,start_vid as ids, end_vid as
idt, array_to_string(array_agg(edge),',') as sequencia,
    array_to_string(array_agg(node),',') as
sequencia_vertex,ST_LineMerge(st_collect(the_geom)) as the_geom,
avg(vel_med) as vel_med
    FROM pgr_dijkstra('SELECT id, source, target, cost, reverse_cost FROM
view_vertex',
        , true)
    join view_vertex t on t.id = edge group by start_vid, end_vid order by
start_vid, end_vid) a;
On Thu, Aug 11, 2016 at 1:42 PM, Omar Fernando Pessôa <omar.pessoa at gmail.com
> wrote:
> Hi guys.
> I am using OSM to generate my road postgis database (south of Brazil).
> My vertex table has 1282959 rows.
> To decrease time to run PGR_DIJKSTRA I have make a box from my
> "destinations" position. Decreasing it to 18264 rows in a materialized view
> with indexes.
> Then running PGR_DIJKSTRA, with k x k (k = 100+-  vertex). The running
> time of PGR_DIJKSTRA is something about 30s.
> This is a good "time"? Can I do it better?
> *drop materialized view if exists view_vertex;*
> *create materialized view view_vertex as((select id, the_geom,
> vel_med,source, target, cost, reverse_cost from vertex_ruas where the_geom
> && 'POLYGON((-49.3954855 -27.0998678,-49.3954855 -26.6055895,-48.7818607
> -26.6055895,-48.7818607 -27.0998678,-49.3954855 -27.0998678))'::geometry
> and status <> 1) UNION ALL(select id, the_geom, vel_med,source, target,
> cost, reverse_cost  from vertex_ruas_aux where the_geom &&
> and status <> 1)); *
> *CREATE UNIQUE INDEX idx_id_view_vertex ON view_vertex(id);*
> *CREATE INDEX idx_source_view_vertex ON view_vertex(source);*
> *CREATE INDEX idx_target_view_vertex ON view_vertex(target);*
> *insert into trajetos select id, ids, idt, st_length(the_geom::geography)
> as distancia , sequencia, sequencia_vertex, the_geom, vel_med from(SELECT
> start_vid || '-' || end_vid as id,start_vid as ids, end_vid as idt,
> avg(vel_med) as vel_med FROM pgr_dijkstra( 'SELECT id, source, target,
> cost, reverse_cost FROM view_vertex' ,
> array[3922267,3922268,3922269,3922270,3922271,3922272,3922273,3922274,3922275,3922276,3922277,3922278,3922279,2667391,3922280,3922281,3922282,3922283,3922284,3922285,3922286,3922287,3922288,3922289,3922290,3922291,3922292,3922293,3922294,3922295,3922296,3922297,3922298,3922299,3922300,3922301,3922302,3922303,3922304,3922305,3922306,3922307,3922308,3922309,3922310,3922311,3922312,3922313,3922314,3922315,3922316,3922317,3922318,3922319,3922320,3922321,3922322,3922323,3922324,3922325,3922326,3922327,3922328,3922329,3922330,3922331,3922332,3922333,3922334,3922335,3922336,3922337,3922338,3922339,3922340,3922341,3922342,3922343,3922344,3922345,3922346,3922347,3922348,3922349,3922350,3922351,3922352,3922353,3922354,3922355,3922356,3922357,3922358,3922359,3922360,3922361,3922362,3922363,3922364,3922365,3922366,3922367,3922368,3922369,3922370],
> true)join view_vertex t on t.id <http://t.id> = edge group by start_vid,
> end_vid order by start_vid, end_vid)a;*
> This is my way to do this. (example).
> Thanks guys! Waiting for withpoints to make me happy. This *vertex_ruas_aux
> *table is a helper table to create new vertex using *ST_LineLocatePoint *from
> *vertex_ruas, *status is set to 1 to make this invalid, generating 2 new
> linestrings *vertex_ruas_aux*.
> *Omar Fernando Pessôa*
> http://www.opessoa.com
> Desenvolvedor de Sistemas / Systems Software Developer
> C++ / PHP / C# / Javascript
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160811/d4da0913/attachment-0001.html>
More information about the Pgrouting-users
