[pgrouting-users] Is this a known problem with tools for solving it or am I on my own?
Vicky Vergara
vicky at georepublic.de
Thu Aug 18 13:51:18 PDT 2016
Hello,
There is this nice site about TSP
http://www.math.uwaterloo.ca/tsp/index.html
this is interesting about the size of a problem:
http://www.math.uwaterloo.ca/tsp/problem/pcb3cnt.html
I don't know how your problem, but sound bigger than 3000 nodes
I would break the problem on smaller problems
btw on the next rlease a new version of pgr_tsp will be available
On Thu, Aug 18, 2016 at 1:33 PM, Greg Stark <stark at mit.edu> wrote:
> I have a set of points distributed throughout the 32 counties of
> Ireland. I want to to plot the quickest route that hits one of the
> points for each county.
> If I had only one point per county it would just be the traveling
> salesperson problem for a fairly trivial problem size. But having more
> than one point per county makes it a different problem I think and in
> fact that's where the numbers get large. I can pare down the points
> per county using other heuristics but the more I pare it down the more
> the path may be suboptimal so I don't want to exclude more points than
> I have to and there are thousands of points for most of the counties.
> Is there an existing tool that would do this or should I try to modify
> pg_tsp to handle this or is this a lost cause?
> Thanks.
> greg
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160818/d14c77a2/attachment.html>
More information about the Pgrouting-users
