[pgrouting-users] Pgrouting on RPI3
Daniel Kastl
daniel at georepublic.de
Mon Jul 4 07:47:16 PDT 2016
First you need to wait until it is published (at this time it still isn't).
Then I would expect, that you install it the same way as for other
platforms:
Daniel
On Mon, Jul 4, 2016 at 11:13 PM, Nico Aliotta <nicoaliotta at gmail.com> wrote:
> Ok seems that is still building the package.
> How i can install it from my S.O.?
> from
> https://launchpad.net/~georepublic/+archive/ubuntu/pgrouting-unstable/+packages
> which command i've to use to install only the armhf version?
> Currently building on bos01-arm64-019
> <https://launchpad.net/builders/bos01-arm64-019>
> - Build score:2510 (What's this?
> <https://help.launchpad.net/Packaging/BuildScores>)
> - Started 7 minutes ago
> 2016-07-04 16:09 GMT+02:00 Daniel Kastl <daniel at georepublic.de>:
>> Hi Nico,
>> Thank you for the link!
>> I think I was able to trigger a build for "ARM ARMv7 Hard Float":
>> Let's see, if it succeeds.
>> For now I rebuild the packages for Ubuntu 14.04 and 16.04.
>> Let me know, if that's enough for now.
>> Cheers,
>> Daniel
>> On Mon, Jul 4, 2016 at 10:49 PM, Nico Aliotta <nicoaliotta at gmail.com>
>> wrote:
>>> maybe i've found how to build an ARM ARMv7 Hard Float (armhf)on
>>> launchpad PPA
>>> here it's the link
>>> http://askubuntu.com/questions/371339/how-to-make-packages-for-arm-in-launchpad
>>> 2016-07-04 10:28 GMT+02:00 Daniel Kastl <daniel at georepublic.de>:
>>>> Hi Nico,
>>>> This is the main page for pgRouting documentation:
>>>> http://docs.pgrouting.org/
>>>> And this is the page to build the latest release:
>>>> http://docs.pgrouting.org/2.2/en/doc/src/installation/build.html
>>>> I don't know how to trigger a build for "arm" on Launchpad PPA.
>>>> It only builds for amd64 and i386, but if you know how to do this,
>>>> please let me know.
>>>> Cheers,
>>>> Daniel
>>>> On Mon, Jul 4, 2016 at 3:23 PM, Nico Aliotta <nicoaliotta at gmail.com>
>>>> wrote:
>>>>> MAybe is this?
>>>>> http://pgrouting.org/docs/1.x/install_ubuntu.html
>>>>> git clone git://github.com/pgRouting/pgrouting.git pgrouting
>>>>> cd pgrouting/
>>>>> cmake -DWITH_TSP=ON -DWITH_DD=ON .
>>>>> make
>>>>> sudo make install
>>>>> ?? and if it's ok is it possible to add in a ppa or add package so that everyone can use it?
>>>>> 2016-07-04 7:19 GMT+02:00 Nico Aliotta <nicoaliotta at gmail.com>:
>>>>>> is it possible to compile pgrouting for raspberrypi3?
>>>>>> that has arm processor? i'musing ubuntu mate 16.04 (arm version)
>>>>>> With sudo apt-get install pgrouting i'm not able.
>>>>>> Where i can find source to compile for arm or packages for ubuntu rpi
>>>>>> version?
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>> Georepublic UG & Georepublic Japan
>>>> eMail: daniel.kastl at georepublic.de
>>>> Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160704/59b7cd17/attachment-0001.html>
More information about the Pgrouting-users
