[pgrouting-users] Pgrouting on RPI3
Nico Aliotta
nicoaliotta at gmail.com
Mon Jul 4 08:10:51 PDT 2016
in the meantime i did
sudo apt-get install postgresql-9.5-pgrouting
and was fine the installation!
Is it complete?
2016-07-04 16:47 GMT+02:00 Daniel Kastl <daniel at georepublic.de>:
> First you need to wait until it is published (at this time it still isn't).
> Then I would expect, that you install it the same way as for other
> platforms:
> Daniel
> On Mon, Jul 4, 2016 at 11:13 PM, Nico Aliotta <nicoaliotta at gmail.com>
> wrote:
>> Ok seems that is still building the package.
>> How i can install it from my S.O.?
>> from
>> https://launchpad.net/~georepublic/+archive/ubuntu/pgrouting-unstable/+packages
>> which command i've to use to install only the armhf version?
>> Currently building on bos01-arm64-019
>> <https://launchpad.net/builders/bos01-arm64-019>
>> - Build score:2510 (What's this?
>> <https://help.launchpad.net/Packaging/BuildScores>)
>> - Started 7 minutes ago
>> 2016-07-04 16:09 GMT+02:00 Daniel Kastl <daniel at georepublic.de>:
>>> Hi Nico,
>>> Thank you for the link!
>>> I think I was able to trigger a build for "ARM ARMv7 Hard Float":
>>> Let's see, if it succeeds.
>>> For now I rebuild the packages for Ubuntu 14.04 and 16.04.
>>> Let me know, if that's enough for now.
>>> Cheers,
>>> Daniel
>>> On Mon, Jul 4, 2016 at 10:49 PM, Nico Aliotta <nicoaliotta at gmail.com>
>>> wrote:
>>>> maybe i've found how to build an ARM ARMv7 Hard Float (armhf)on
>>>> launchpad PPA
>>>> here it's the link
>>>> http://askubuntu.com/questions/371339/how-to-make-packages-for-arm-in-launchpad
>>>> 2016-07-04 10:28 GMT+02:00 Daniel Kastl <daniel at georepublic.de>:
>>>>> Hi Nico,
>>>>> This is the main page for pgRouting documentation:
>>>>> http://docs.pgrouting.org/
>>>>> And this is the page to build the latest release:
>>>>> http://docs.pgrouting.org/2.2/en/doc/src/installation/build.html
>>>>> I don't know how to trigger a build for "arm" on Launchpad PPA.
>>>>> It only builds for amd64 and i386, but if you know how to do this,
>>>>> please let me know.
>>>>> Cheers,
>>>>> Daniel
>>>>> On Mon, Jul 4, 2016 at 3:23 PM, Nico Aliotta <nicoaliotta at gmail.com>
>>>>> wrote:
>>>>>> MAybe is this?
>>>>>> http://pgrouting.org/docs/1.x/install_ubuntu.html
>>>>>> git clone git://github.com/pgRouting/pgrouting.git pgrouting
>>>>>> cd pgrouting/
>>>>>> cmake -DWITH_TSP=ON -DWITH_DD=ON .
>>>>>> make
>>>>>> sudo make install
>>>>>> ?? and if it's ok is it possible to add in a ppa or add package so that everyone can use it?
>>>>>> 2016-07-04 7:19 GMT+02:00 Nico Aliotta <nicoaliotta at gmail.com>:
>>>>>>> is it possible to compile pgrouting for raspberrypi3?
>>>>>>> that has arm processor? i'musing ubuntu mate 16.04 (arm version)
>>>>>>> With sudo apt-get install pgrouting i'm not able.
>>>>>>> Where i can find source to compile for arm or packages for ubuntu
>>>>>>> rpi version?
>>>>>> _______________________________________________
>>>>>> Pgrouting-users mailing list
>>>>>> Pgrouting-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>>> Georepublic UG & Georepublic Japan
>>>>> eMail: daniel.kastl at georepublic.de
>>>>> Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160704/f4d4484b/attachment.html>
More information about the Pgrouting-users
