[pgrouting-users] Pgrouting on RPI3
Vicky Vergara vicky at georepublic.de
Mon Jul 4 22:12:41 PDT 2016
Hi Nico:
create extension postgis;
create extension pgRouting
SELECT pgr_version();
it should be 2.2.3
Vicky
On Mon, Jul 4, 2016 at 10:10 AM, Nico Aliotta <nicoaliotta at gmail.com> wrote:
> in the meantime i did
> sudo apt-get install postgresql-9.5-pgrouting
> and was fine the installation!
> Is it complete?
> 2016-07-04 16:47 GMT+02:00 Daniel Kastl <daniel at georepublic.de>:
>> First you need to wait until it is published (at this time it still
>> isn't).
>> Then I would expect, that you install it the same way as for other
>> platforms:
>> Daniel
>> On Mon, Jul 4, 2016 at 11:13 PM, Nico Aliotta <nicoaliotta at gmail.com>
>> wrote:
>>> Ok seems that is still building the package.
>>> How i can install it from my S.O.?
>>> from
>>> https://launchpad.net/~georepublic/+archive/ubuntu/pgrouting-unstable/+packages
>>> which command i've to use to install only the armhf version?
>>> Currently building on bos01-arm64-019
>>> <https://launchpad.net/builders/bos01-arm64-019>
>>>    - Build score:2510 (What's this?
>>>    <https://help.launchpad.net/Packaging/BuildScores>)
>>>    - Started 7 minutes ago
>>> 2016-07-04 16:09 GMT+02:00 Daniel Kastl <daniel at georepublic.de>:
>>>> Hi Nico,
>>>> Thank you for the link!
>>>> I think I was able to trigger a build for "ARM ARMv7 Hard Float":
>>>> Let's see, if it succeeds.
>>>> For now I rebuild the packages for Ubuntu 14.04 and 16.04.
>>>> Let me know, if that's enough for now.
>>>> Cheers,
>>>> Daniel
>>>> On Mon, Jul 4, 2016 at 10:49 PM, Nico Aliotta <nicoaliotta at gmail.com>
>>>> wrote:
>>>>> maybe i've found how to build an ARM ARMv7 Hard Float (armhf)on
>>>>> launchpad PPA
>>>>> here it's the link
>>>>> http://askubuntu.com/questions/371339/how-to-make-packages-for-arm-in-launchpad
>>>>> 2016-07-04 10:28 GMT+02:00 Daniel Kastl <daniel at georepublic.de>:
>>>>>> Hi Nico,
>>>>>> This is the main page for pgRouting documentation:
>>>>>> http://docs.pgrouting.org/
>>>>>> And this is the page to build the latest release:
>>>>>> http://docs.pgrouting.org/2.2/en/doc/src/installation/build.html
>>>>>> I don't know how to trigger a build for "arm" on Launchpad PPA.
>>>>>> It only builds for amd64 and i386, but if you know how to do this,
>>>>>> please let me know.
>>>>>> Cheers,
>>>>>> Daniel
>>>>>> On Mon, Jul 4, 2016 at 3:23 PM, Nico Aliotta <nicoaliotta at gmail.com>
>>>>>> wrote:
>>>>>>> MAybe is this?
>>>>>>> http://pgrouting.org/docs/1.x/install_ubuntu.html
>>>>>>> git clone git://github.com/pgRouting/pgrouting.git pgrouting
>>>>>>> cd pgrouting/
>>>>>>> cmake -DWITH_TSP=ON -DWITH_DD=ON .
>>>>>>> make
>>>>>>> sudo make install
>>>>>>> ?? and if it's ok is it possible to add in a ppa or add package so that everyone can use it?
>>>>>>> 2016-07-04 7:19 GMT+02:00 Nico Aliotta <nicoaliotta at gmail.com>:
>>>>>>>> is it possible to compile pgrouting for raspberrypi3?
>>>>>>>> that has arm processor? i'musing ubuntu mate 16.04 (arm version)
>>>>>>>> With sudo apt-get install pgrouting i'm not able.
>>>>>>>> Where i can find source to compile for arm or packages for ubuntu
>>>>>>>> rpi version?
>>>>>>> _______________________________________________
>>>>>>> Pgrouting-users mailing list
>>>>>>> Pgrouting-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>>>> Georepublic UG & Georepublic Japan
>>>>>> eMail: daniel.kastl at georepublic.de
>>>>>> Web: http://georepublic.info
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160705/43688e19/attachment.html>
More information about the Pgrouting-users mailing list
