[pgrouting-users] Problem with topology using sample data in the manual
Regina Obe
lr at pcorp.us
Fri May 13 21:24:18 PDT 2016
Quick note.
There were some issues in pgRouting 2.2.0 released which this may be one of them. I pushed up pgRouting 2.2.2 in stackbuilder last week for PostgreSQL 9.5 x windows 64-bit
If you reinstall PostGIS bundle from stackbuilder and then do a
ALTER EXTENSION pgRouting UPDATE;
You should get the new version.
For others on windows, sorry haven't had a chance to repackage. I do have binaries you can get from here - http://postgis.net/windows_downloads/
In the unreleased section – look for in respective pg version folder
pgrouting-pg95-binaries-2.2.2w64gcc48.zip <http://winnie.postgis.net/download/windows/pg95/buildbot/pgrouting-pg95-binaries-2.2.2w64gcc48.zip>
Where the 95, w64 will change depending on which version of PostgreSQL you are running.
These will be the same versions I'll be pushing up.
Thanks,
Regina
From: Pgrouting-users [mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of HuanChun Ye
Sent: Friday, May 13, 2016 11:57 PM
To: pgrouting-users at lists.osgeo.org
Subject: [pgrouting-users] Problem with topology using sample data in the manual
I am working through the examples in the manual (v2.2) using the sample data, but encountered a problem with topology, as described below. I apologize for the verbosity, but I want to show the exact steps leading to the problem, starting with just after importing the sample data:
pgr_sample=# select * from edge_table;
id | dir | source | target | cost | reverse_cost | x1 | y1 | x2 | y2 | the_geom
1 | B | | | 1 | 1 | 2 | 0 | 2 | 1 | 010200000002000000000000000000004000000000000000000000000000000040000000000000F03F
2 | TF | | | -1 | 1 | 2 | 1 | 3 | 1 | 0102000000020000000000000000000040000000000000F03F0000000000000840000000000000F03F
3 | TF | | | -1 | 1 | 3 | 1 | 4 | 1 | 0102000000020000000000000000000840000000000000F03F0000000000001040000000000000F03F
4 | B | | | 1 | 1 | 2 | 1 | 2 | 2 | 0102000000020000000000000000000040000000000000F03F00000000000000400000000000000040
5 | FT | | | 1 | -1 | 3 | 1 | 3 | 2 | 0102000000020000000000000000000840000000000000F03F00000000000008400000000000000040
6 | B | | | 1 | 1 | 0 | 2 | 1 | 2 | 01020000000200000000000000000000000000000000000040000000000000F03F0000000000000040
7 | B | | | 1 | 1 | 1 | 2 | 2 | 2 | 010200000002000000000000000000F03F000000000000004000000000000000400000000000000040
8 | B | | | 1 | 1 | 2 | 2 | 3 | 2 | 0102000000020000000000000000000040000000000000004000000000000008400000000000000040
9 | B | | | 1 | 1 | 3 | 2 | 4 | 2 | 0102000000020000000000000000000840000000000000004000000000000010400000000000000040
10 | B | | | 1 | 1 | 2 | 2 | 2 | 3 | 0102000000020000000000000000000040000000000000004000000000000000400000000000000840
11 | FT | | | 1 | -1 | 3 | 2 | 3 | 3 | 0102000000020000000000000000000840000000000000004000000000000008400000000000000840
12 | FT | | | 1 | -1 | 2 | 3 | 3 | 3 | 0102000000020000000000000000000040000000000000084000000000000008400000000000000840
13 | FT | | | 1 | -1 | 3 | 3 | 4 | 3 | 0102000000020000000000000000000840000000000000084000000000000010400000000000000840
14 | B | | | 1 | 1 | 2 | 3 | 2 | 4 | 0102000000020000000000000000000040000000000000084000000000000000400000000000001040
15 | B | | | 1 | 1 | 4 | 2 | 4 | 3 | 0102000000020000000000000000001040000000000000004000000000000010400000000000000840
16 | B | | | 1 | 1 | 4 | 1 | 4 | 2 | 0102000000020000000000000000001040000000000000F03F00000000000010400000000000000040
17 | B | | | 1 | 1 | 0.5 | 3.5 | 1.999999999999 | 3.5 | 010200000002000000000000000000E03F0000000000000C4068EEFFFFFFFFFF3F0000000000000C40
18 | B | | | 1 | 1 | 3.5 | 2.3 | 3.5 | 4 | 0102000000020000000000000000000C4066666666666602400000000000000C400000000000001040
(18 rows)
pgr_sample=# select pgr_createTopology('edge_table', 0.001);
NOTICE: PROCESSING:
NOTICE: pgr_createTopology('edge_table', 0.001, 'the_geom', 'id', 'source', 'target', rows_where := 'true', clean := f)
NOTICE: Performing checks, please wait .....
NOTICE: Creating Topology, Please wait...
NOTICE: -------------> TOPOLOGY CREATED FOR 18 edges
NOTICE: Rows with NULL geometry or NULL id: 0
NOTICE: Vertices table for table public.edge_table is: public.edge_table_vertices_pgr
NOTICE: ----------------------------------------------
pgr_createtopology
OK
(1 row)
pgr_sample=# select pgr_analyzeGraph('edge_table', 0.001);
NOTICE: PROCESSING:
NOTICE: pgr_analyzeGraph('edge_table',0.001,'the_geom','id','source','target','true')
NOTICE: Analyzing for dead ends. Please wait...
NOTICE: Analyzing for gaps. Please wait...
NOTICE: Analyzing for isolated edges. Please wait...
NOTICE: Analyzing for ring geometries. Please wait...
NOTICE: Analyzing for intersections. Please wait...
NOTICE: ANALYSIS RESULTS FOR SELECTED EDGES:
NOTICE: Isolated segments: 2
NOTICE: Dead ends: 7
NOTICE: Potential gaps found near dead ends: 1
NOTICE: Intersections detected: 1
NOTICE: Ring geometries: 0
pgr_analyzegraph
OK
(1 row)
pgr_sample=# select pgr_nodeNetwork('edge_table', 0.001);
NOTICE: PROCESSING:
NOTICE: pgr_nodeNetwork('edge_table', 0.001, 'id', 'the_geom', 'noded', '<NULL>', f)
NOTICE: Processing, please wait .....
NOTICE: Splitted Edges: 2
NOTICE: Untouched Edges: 16
NOTICE: Total original Edges: 18
NOTICE: Edges generated: 4
NOTICE: Total New segments: 20
NOTICE: New Table: public.edge_table_noded
pgr_nodenetwork
OK
(1 row)
pgr_sample=# select pgr_createTopology('edge_table_noded', 0.001);
NOTICE: PROCESSING:
NOTICE: pgr_createTopology('edge_table_noded', 0.001, 'the_geom', 'id', 'source', 'target', rows_where := 'true', clean := f)
NOTICE: -------------> TOPOLOGY CREATED FOR 20 edges
NOTICE: Vertices table for table public.edge_table_noded is: public.edge_table_noded_vertices_pgr
pgr_createtopology
OK
(1 row)
pgr_sample=# select pgr_analyzeGraph('edge_table_noded', 0.001);
NOTICE: PROCESSING:
NOTICE: pgr_analyzeGraph('edge_table_noded',0.001,'the_geom','id','source','target','true')
NOTICE: Isolated segments: 1
NOTICE: Intersections detected: 0
pgr_analyzegraph
OK
(1 row)
pgr_sample=# SELECT a.*
pgr_sample-# FROM edge_table_noded a, edge_table_noded_vertices_pgr b, edge_table_noded_vertices_pgr c
pgr_sample-# WHERE a.source=b.id <http://b.id> AND b.cnt=1 AND a.target=c.id <http://c.id> AND c.cnt=1;
id | old_id | sub_id | source | target | the_geom
20 | 17 | 1 | 17 | 18 | 010200000002000000000000000000E03F0000000000000C4068EEFFFFFFFFFF3F0000000000000C40
(1 row)
So the original node id 17, which is a nearly touching T-intersection, remains isolated. This is in contrast to the output shown in the manual, which shows the following:
SELECT pgr_analyzegraph('edge_table_noded', 0.001);
NOTICE: PROCESSING:
NOTICE: Performing checks, pelase wait...
NOTICE: Isolated segments: 0
NOTICE: Dead ends: 6
NOTICE: Potential gaps found near dead ends: 0
pgr_createtopology
OK
(1 row)
I tried the following but none helped:
- increasing the value of tolerance up to 0.5
- setting the SRID of the geometry column
- converting data to .osm file and run osm2pgrouting
I am using the following versions on Windows 10 64-bit PC:
pgr_sample=# select version(), postgis_full_version(), pgr_version();
version | postgis_full_version
| pgr_version
PostgreSQL 9.5.2, compiled by Visual C++ build 1800, 64-bit | POSTGIS="2.2.2 r14797" GEOS="3.5.0-CAPI-1.9.0 r4090" PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.0.2, re
leased 2016/01/26" LIBXML="2.7.8" LIBJSON="0.12" RASTER | (2.2.0,pgrouting-2.2.0,afc622e,master,1.59.0)
(1 row)
Thanks in advance for your help!
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160514/0d095906/attachment-0001.html>
More information about the Pgrouting-users
