[pgrouting-users] Problem with topology using sample data in the manual
Vicky Vergara
vicky at georepublic.de
Sat May 14 08:12:57 PDT 2016
Can you give me the link of the documentation that you are following?
So that I can follow it.
Vicky
On Fri, May 13, 2016 at 10:56 PM, HuanChun Ye <huanchunye at athentek.com>
wrote:
> I am working through the examples in the manual (v2.2) using the sample
> data, but encountered a problem with topology, as described below. I
> apologize for the verbosity, but I want to show the exact steps leading to
> the problem, starting with just after importing the sample data:
> pgr_sample=# select * from edge_table;
> id | dir | source | target | cost | reverse_cost | x1 | y1 | x2
> | y2 | the_geom
> 1 | B | | | 1 | 1 | 2 | 0 |
> 2 | 1 |
> 010200000002000000000000000000004000000000000000000000000000000040000000000000F03F
> 2 | TF | | | -1 | 1 | 2 | 1 |
> 3 | 1 |
> 0102000000020000000000000000000040000000000000F03F0000000000000840000000000000F03F
> 3 | TF | | | -1 | 1 | 3 | 1 |
> 4 | 1 |
> 0102000000020000000000000000000840000000000000F03F0000000000001040000000000000F03F
> 4 | B | | | 1 | 1 | 2 | 1 |
> 2 | 2 |
> 0102000000020000000000000000000040000000000000F03F00000000000000400000000000000040
> 5 | FT | | | 1 | -1 | 3 | 1 |
> 3 | 2 |
> 0102000000020000000000000000000840000000000000F03F00000000000008400000000000000040
> 6 | B | | | 1 | 1 | 0 | 2 |
> 1 | 2 |
> 01020000000200000000000000000000000000000000000040000000000000F03F0000000000000040
> 7 | B | | | 1 | 1 | 1 | 2 |
> 2 | 2 |
> 010200000002000000000000000000F03F000000000000004000000000000000400000000000000040
> 8 | B | | | 1 | 1 | 2 | 2 |
> 3 | 2 |
> 0102000000020000000000000000000040000000000000004000000000000008400000000000000040
> 9 | B | | | 1 | 1 | 3 | 2 |
> 4 | 2 |
> 0102000000020000000000000000000840000000000000004000000000000010400000000000000040
> 10 | B | | | 1 | 1 | 2 | 2 |
> 2 | 3 |
> 0102000000020000000000000000000040000000000000004000000000000000400000000000000840
> 11 | FT | | | 1 | -1 | 3 | 2 |
> 3 | 3 |
> 0102000000020000000000000000000840000000000000004000000000000008400000000000000840
> 12 | FT | | | 1 | -1 | 2 | 3 |
> 3 | 3 |
> 0102000000020000000000000000000040000000000000084000000000000008400000000000000840
> 13 | FT | | | 1 | -1 | 3 | 3 |
> 4 | 3 |
> 0102000000020000000000000000000840000000000000084000000000000010400000000000000840
> 14 | B | | | 1 | 1 | 2 | 3 |
> 2 | 4 |
> 0102000000020000000000000000000040000000000000084000000000000000400000000000001040
> 15 | B | | | 1 | 1 | 4 | 2 |
> 4 | 3 |
> 0102000000020000000000000000001040000000000000004000000000000010400000000000000840
> 16 | B | | | 1 | 1 | 4 | 1 |
> 4 | 2 |
> 0102000000020000000000000000001040000000000000F03F00000000000010400000000000000040
> 17 | B | | | 1 | 1 | 0.5 | 3.5 |
> 1.999999999999 | 3.5 |
> 010200000002000000000000000000E03F0000000000000C4068EEFFFFFFFFFF3F0000000000000C40
> 18 | B | | | 1 | 1 | 3.5 | 2.3 |
> 3.5 | 4 |
> 0102000000020000000000000000000C4066666666666602400000000000000C400000000000001040
> (18 rows)
> pgr_sample=# select pgr_createTopology('edge_table', 0.001);
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology('edge_table', 0.001, 'the_geom', 'id',
> 'source', 'target', rows_where := 'true', clean := f)
> NOTICE: Performing checks, please wait .....
> NOTICE: Creating Topology, Please wait...
> NOTICE: -------------> TOPOLOGY CREATED FOR 18 edges
> NOTICE: Rows with NULL geometry or NULL id: 0
> NOTICE: Vertices table for table public.edge_table is:
> public.edge_table_vertices_pgr
> NOTICE: ----------------------------------------------
> pgr_createtopology
> OK
> (1 row)
> pgr_sample=# select pgr_analyzeGraph('edge_table', 0.001);
> NOTICE: PROCESSING:
> NOTICE:
> pgr_analyzeGraph('edge_table',0.001,'the_geom','id','source','target','true')
> NOTICE: Analyzing for dead ends. Please wait...
> NOTICE: Analyzing for gaps. Please wait...
> NOTICE: Analyzing for isolated edges. Please wait...
> NOTICE: Analyzing for ring geometries. Please wait...
> NOTICE: Analyzing for intersections. Please wait...
> NOTICE: ANALYSIS RESULTS FOR SELECTED EDGES:
> NOTICE: Isolated segments: 2
> NOTICE: Dead ends: 7
> NOTICE: Potential gaps found near dead ends: 1
> NOTICE: Intersections detected: 1
> NOTICE: Ring geometries: 0
> pgr_analyzegraph
> OK
> (1 row)
> pgr_sample=# select pgr_nodeNetwork('edge_table', 0.001);
> NOTICE: PROCESSING:
> NOTICE: pgr_nodeNetwork('edge_table', 0.001, 'id', 'the_geom', 'noded',
> '<NULL>', f)
> NOTICE: Processing, please wait .....
> NOTICE: Splitted Edges: 2
> NOTICE: Untouched Edges: 16
> NOTICE: Total original Edges: 18
> NOTICE: Edges generated: 4
> NOTICE: Total New segments: 20
> NOTICE: New Table: public.edge_table_noded
> pgr_nodenetwork
> OK
> (1 row)
> pgr_sample=# select pgr_createTopology('edge_table_noded', 0.001);
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology('edge_table_noded', 0.001, 'the_geom', 'id',
> NOTICE: -------------> TOPOLOGY CREATED FOR 20 edges
> NOTICE: Vertices table for table public.edge_table_noded is:
> public.edge_table_noded_vertices_pgr
> pgr_createtopology
> OK
> (1 row)
> pgr_sample=# select pgr_analyzeGraph('edge_table_noded', 0.001);
> NOTICE: PROCESSING:
> NOTICE:
> pgr_analyzeGraph('edge_table_noded',0.001,'the_geom','id','source','target','true')
> NOTICE: Isolated segments: 1
> NOTICE: Intersections detected: 0
> pgr_analyzegraph
> OK
> (1 row)
> pgr_sample=# SELECT a.*
> pgr_sample-# FROM edge_table_noded a, edge_table_noded_vertices_pgr b,
> edge_table_noded_vertices_pgr c
> pgr_sample-# WHERE a.source=b.id AND b.cnt=1 AND a.target=c.id AND
> c.cnt=1;
> id | old_id | sub_id | source | target |
> the_geom
> 20 | 17 | 1 | 17 | 18 |
> (1 row)
> So the original node id 17, which is a nearly touching T-intersection,
> remains isolated. This is in contrast to the output shown in the manual,
> which shows the following:
> SELECT pgr_analyzegraph('edge_table_noded', 0.001);NOTICE: PROCESSING:NOTICE: pgr_analyzeGraph('edge_table_noded',0.001,'the_geom','id','source','target','true')NOTICE: Performing checks, pelase wait...NOTICE: Analyzing for dead ends. Please wait...NOTICE: Analyzing for gaps. Please wait...NOTICE: Analyzing for isolated edges. Please wait...NOTICE: Analyzing for ring geometries. Please wait...NOTICE: Analyzing for intersections. Please wait...NOTICE: ANALYSIS RESULTS FOR SELECTED EDGES:NOTICE: Isolated segments: 0NOTICE: Dead ends: 6NOTICE: Potential gaps found near dead ends: 0NOTICE: Intersections detected: 0NOTICE: Ring geometries: 0pgr_createtopology--------------------
> OK(1 row)
> I tried the following but none helped:
> - increasing the value of tolerance up to 0.5
> - setting the SRID of the geometry column
> - converting data to .osm file and run osm2pgrouting
> I am using the following versions on Windows 10 64-bit PC:
> pgr_sample=# select version(), postgis_full_version(), pgr_version();
> version |
> pgr_version
> PostgreSQL 9.5.2, compiled by Visual C++ build 1800, 64-bit |
> POSTGIS="2.2.2 r14797" GEOS="3.5.0-CAPI-1.9.0 r4090" PROJ="Rel. 4.9.1, 04
> March 2015" GDAL="GDAL 2.0.2, re
> leased 2016/01/26" LIBXML="2.7.8" LIBJSON="0.12" RASTER |
> (2.2.0,pgrouting-2.2.0,afc622e,master,1.59.0)
> (1 row)
> Thanks in advance for your help!
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160514/b54ce938/attachment-0001.html>
More information about the Pgrouting-users
