[pgrouting-users] Possible documentation error
Dave Potts mrdapotts at gmail.com
Tue Oct 17 13:12:58 PDT 2017
Hi List
Sorry if this is wrong but in pgRoutingDocumentation-2.3.2.pdf page 16
There is a reference to a edge table
I think a column is missing from_cost
This assumes that to_cost isthe cost off getting from source to target,
then from cost is the cost of going the other way
It might also help me to populate this table if I knew what then columns
were,  I can make an educated guess, but I would like tosee it
I have assumed
cost_len       is the length ofthe ling between source and target
cost_time     is the time it takes to get between the source and the target
The rcost_len and rcost_time are the values for the reverse journey
x1/y1is the location of source
x2/y2 is the location of the target
I have no clue what rule and isolated should be set to
When it comes to analysing a graph is very useful to know that you can say
SELECT
pgr_analyzegraph('concl_edge_table',0.00005,source:='source_port_id',target:='target_port_id',the_geom:='port_geom');
Just incase your source and target colums are not called source or target,
ditto the_geom fieldneeds to be documented in the edge_table
regards
Dave.
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20171017/6e58acfc/attachment.html>
More information about the Pgrouting-users mailing list
