[pgrouting-users] pointsOfInterest table
Vicky Vergara
vicky at georepublic.de
Sat Oct 21 06:49:08 PDT 2017
Hi Dave
Sorry I didnt make documentation about the new table,
I am on a trip, so for the moment I can tell you based on this code
https://github.com/pgRouting/osm2pgrouting/blob/master/src/database/pois_config.cpp#L49
There is no X / Y columns
fraction is the fraction of the edge
because 0 and 1 are whole numbers vertex_id would be the corresponding
vertex of the point of interest
there is a column new_geom which would have the new geometry if a point was
found in the topology (aka was not too far)
When I have time I will try to elaborate the documentation of this table,
Vicky
On Thu, Oct 19, 2017 at 9:16 PM, Dave Potts <mrdapotts at gmail.com> wrote:
> Can anybody confirm that the in the table are as follows
> CREATE TABLE pointsOfInterest( pid BIGSERIAL,
> x FLOAT,
> y FLOAT,
> edge_id BIGINT,
> side CHAR,
> fraction FLOAT,
> the_geom geometry,
> newPoint geometry );
> pid primary key the table
> x/y coordinates of teh point of interest
> edge_id the nearest edge id to this point of interest
> has a value of l r b ?
> fraction ?
> the_geom the geometry of the point
> newPoint the nearest point on the edge that is closest to this point
> Any suggestions welcome
> Dave.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20171021/3fda8983/attachment.html>
More information about the Pgrouting-users
