[pgrouting-users] pointsOfInterest table
Dave Potts mrdapotts at gmail.com
Sat Oct 21 07:45:47 PDT 2017
Thanks I will try and figure it out tomorrow.
an
I am currently having fun with the flow stuff
I think one of the issues is that this methods can generate a result, but
you need to know what the result means!
Dave.
On 21 October 2017 at 14:49, Vicky Vergara <vicky at georepublic.de> wrote:
> Hi Dave
> Sorry I didnt make documentation about the new table,
> I am on a trip, so for the moment I can tell you based on this code
> https://github.com/pgRouting/osm2pgrouting/blob/master/src/
> database/pois_config.cpp#L49
> There is no X / Y columns
> fraction is the fraction of the edge
> because 0 and 1 are whole numbers vertex_id would be the corresponding
> vertex of the point of interest
> there is a column new_geom which would have the new geometry if a point
> was found in the topology (aka was not too far)
> When I have time I will try to elaborate the documentation of this table,
> Vicky
> On Thu, Oct 19, 2017 at 9:16 PM, Dave Potts <mrdapotts at gmail.com> wrote:
>> Can anybody confirm that the  in the table are as follows
>> CREATE TABLE pointsOfInterest( pid BIGSERIAL,
>>  x FLOAT,
>> y FLOAT,
>>  edge_id BIGINT,
>> side CHAR,
>> fraction FLOAT,
>>  the_geom geometry,
>>  newPoint geometry );
>> pid primary key the table
>> x/y   coordinates of teh point of interest
>> edge_id   the nearest edge id to this point of interest
>> has a value of l r b  ?
>> fraction ?
>> the_geom the geometry of the point
>> newPoint  the nearest point on the edge that is closest to this point
>> Any suggestions welcome
>> Dave.
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20171021/29047c53/attachment.html>
More information about the Pgrouting-users mailing list
