[pgrouting-users] possible bug in pgr_maxFlowPushRelabel
Dave Potts mrdapotts at gmail.com
Sun Oct 22 12:08:11 PDT 2017
I was just looking at Many to one version, the example reads
SELECT * FROM pgr_maxFlowPushRelabel(
    'SELECT id,
            source,
            target,
            c1.capacity as capacity,
            c2.capacity as reverse_capacity
    FROM edge_table JOIN categories AS c1 USING(category_id), categories AS c2
    WHERE edge_table.reverse_category_id = c2.category_id
    ORDER BY id'
    , ARRAY[6, 8, 12], 11
ie get the max flow from nodes 6 8 and 12 to 11
The listed result sets says
 seq | edge_id | source | target | flow | residual_capacity
   1 |      10 |      5 |     10 |  100 |                30
   2 |       8 |      6 |      5 |  100 |                30
   3 |      11 |      6 |     11 |  130 |                 0
   4 |      12 |     10 |     11 |  100 |                 0
   5 |      13 |     12 |     11 |   50 |                 0
The results list includes reference from 6 and 12 BUT NOTHING from 8
if I remove the ORDER BY id clause I get
   2 |      11 |      6 |     11 |  130 |                 0
   3 |       8 |      6 |      5 |   50 |                80
   4 |       7 |      8 |      5 |   50 |                 0
   5 |      12 |     10 |     11 |  100 |                 0
   6 |      13 |     12 |     11 |   50 |                 0
ie the result for node 8 is included, is the order by a requirment? is
this a bug ?
regards
Dave.
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20171022/c4b6f142/attachment.html>
More information about the Pgrouting-users mailing list
