[pgrouting-users] pgr_nodenetwork
Toni Hérnández toni.hernandez at udg.edu
Thu Mar 15 08:03:20 PDT 2018
Hello,
I have been trying to make some sense of the function pgr_nodenetwork,
but I haven't succeeded.
Based on the documentation, this function "Nodes an network edge
table.(...).  What we mean by “noded” is that at every intersection in
the road network all the edges will be broken into separate road segments"
I have been doing tests for the last couple of days. You can reproduce a
simple one, by executing the following SQL statements.
-- Create test_graph table and insert two geometries
SET CLIENT_ENCODING TO UTF8;
SET STANDARD_CONFORMING_STRINGS TO ON;
BEGIN;
CREATE TABLE "test_graph" (gid serial,
"id" numeric(10,0),
"nom" varchar(80));
ALTER TABLE "test_graph" ADD PRIMARY KEY (gid);
SELECT AddGeometryColumn('','test_graph','geom','25831','LINESTRING',2);
INSERT INTO "test_graph" ("id","nom",geom) VALUES
('3',NULL,'0102000020E764000008000000F281433F6B731A41C84583B869855141592275DD14731A41C89C7A7D73855141B3E5D70CD3721A4164B5681680855141BFC2A67BBE721A419A3856BE8585514137F861B0A1721A41D72C1EC58F855141D87C445995721A413DC21EB6968551416D2458939D721A41DFF4EFE89D85514137F861B0A1721A411578DD90A3855141');
('5',NULL,'0102000020E76400000900000065D6DA5A51701A410D5914A88B855141DA9E3C70E5701A4106E8394987855141ADE2BBDC85711A415E9B857C85855141C32F009B0D721A416B2643758485514150B2FF8D78721A41A8C313B784855141BFC2A67BBE721A419A3856BE85855141930626E85E731A4135FA4C92888551414E90077728741A418D04908A90855141A5E6108797741A41F399907B97855141');
COMMIT;
ANALYZE "test_graph";
-- Try to node the network.
select pgr_nodenetwork ('test_Graph', 0.01, 'gid', 'geom');
You can see the geometries on images, before
(http://sigserver4.udg.edu/apps/original_geometries.png) and after
(http://sigserver4.udg.edu/apps/noded_geometries.png), the noding proces.
The result, is a set of 6 rows but the segments generated are not the
expected ones.
Does anyone know what's happening here?
Thanks for your help.
*Toni Hernández Vallès*
Servei de Sistemes d'Informació Geogràfica i Teledetecció
Universitat de Girona
*SIGTE*
Pl. Ferrater Mora 1
17071 Girona
Tel +34 972 418 039 (7026 intern)
toni.hernandez at udg.edu <mailto:toni.hernandez at udg.edu>
http://www.sigte.udg.edu
Twitter http://twitter.com/SIGTE_UDG
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20180315/7803b09e/attachment.html>
More information about the Pgrouting-users mailing list
