[pgrouting-users] pgr_nodenetwork
Daniel Kastl daniel at georepublic.de
Thu Mar 15 20:24:00 PDT 2018
Thank you for reporting the issue and the easy to reproduce test case!
I tried with a different projection, but the issue remained.
I think, it's better to track this in the pgRouting Github repository, so I
created the following issue:
https://github.com/pgRouting/pgrouting/issues/1009
Best regards,
Daniel
On Fri, Mar 16, 2018 at 12:03 AM, Toni Hérnández <toni.hernandez at udg.edu>
wrote:
> Hello,
> I have been trying to make some sense of the function pgr_nodenetwork, but
> I haven't succeeded.
> Based on the documentation, this function "Nodes an network edge
> table.(...).  What we mean by “noded” is that at every intersection in the
> road network all the edges will be broken into separate road segments"
> I have been doing tests for the last couple of days. You can reproduce a
> simple one, by executing the following SQL statements.
> -- Create test_graph table and insert two geometries
> SET CLIENT_ENCODING TO UTF8;
> SET STANDARD_CONFORMING_STRINGS TO ON;
> BEGIN;
> CREATE TABLE "test_graph" (gid serial,
> "id" numeric(10,0),
> "nom" varchar(80));
> ALTER TABLE "test_graph" ADD PRIMARY KEY (gid);
> SELECT AddGeometryColumn('','test_graph','geom','25831','LINESTRING',2);
> INSERT INTO "test_graph" ("id","nom",geom) VALUES ('3',NULL,'
> 0102000020E764000008000000F281433F6B731A41C84583B86985514159
> 2275DD14731A41C89C7A7D73855141B3E5D70CD3721A4164B56816808551
> 41BFC2A67BBE721A419A3856BE8585514137F861B0A1721A41D72C1EC58F
> 855141D87C445995721A413DC21EB6968551416D2458939D721A41DFF4EF
> E89D85514137F861B0A1721A411578DD90A3855141');
> INSERT INTO "test_graph" ("id","nom",geom) VALUES ('5',NULL,'
> 0102000020E76400000900000065D6DA5A51701A410D5914A88B855141DA
> 9E3C70E5701A4106E8394987855141ADE2BBDC85711A415E9B857C858551
> 41C32F009B0D721A416B2643758485514150B2FF8D78721A41A8C313B784
> 855141BFC2A67BBE721A419A3856BE85855141930626E85E731A4135FA4C
> 92888551414E90077728741A418D04908A90855141A5E6108797741A41F3
> 99907B97855141');
> COMMIT;
> ANALYZE "test_graph";
> -- Try to node the network.
> select pgr_nodenetwork ('test_Graph', 0.01, 'gid', 'geom');
> You can see the geometries on images, before (http://sigserver4.udg.edu/
> apps/original_geometries.png) and after (http://sigserver4.udg.edu/
> apps/noded_geometries.png), the noding proces.
> The result, is a set of 6 rows but the segments generated are not the
> expected ones.
> Does anyone know what's happening here?
> Thanks for your help.
> *Toni Hernández Vallès*
> Servei de Sistemes d'Informació Geogràfica i Teledetecció
> Universitat de Girona
> *SIGTE*
> Pl. Ferrater Mora 1
> 17071 Girona
> Tel +34 972 418 039 <+34%20972%2041%2080%2039> (7026 intern)
> http://www.sigte.udg.edu
> Twitter http://twitter.com/SIGTE_UDG
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: https://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20180316/3dc2373b/attachment.html>
More information about the Pgrouting-users mailing list
