[pgrouting-users] RFC3 Positional and named parameters on pgRouting functions
Vicky Vergara vicky at georepublic.de
Thu Oct 25 10:06:42 PDT 2018
Hi Dave,
"Normally" people use functions with positional parameters.
(about my quotes in words read [1])
Using proposed function *pgr_dijkstraCost* as example:
When you write a function call:
SELECT * FROM *pgr_dijkstraCost*('SELECT * from edge_table', 2, 3);
SELECT * FROM* pgr_dijkstraCost*('SELECT * from edge_table', 2, 3, false);
This works also (mixed)
SELECT * FROM *pgr_dijkstraCost*('SELECT * from edge_table', 2, 3,
directed:=false);
No one has complained that this can't be done on 2.6 (or for the last 2
years for that matter) on the function *pgr_dijkstraCost*:
SELECT * FROM *pgr_dijkstraCost*(edge_sql:='SELECT * from edge_table',
start_vid:=2, end_vid:=3);
I would think that is because "normally" people use functions with
The changes are on the function calls, not on the function's return column
names.
So if you application has a wrapper:
CREATE FUNCTION mywarper1(...)
RETURN QUERY
SELECT end_vid, cost FROM *pgr_dijkstraCost*('SELECT * from edge_table', 2,
3);
The columns end_vid & cost names are not changed, so your warpper is ok
In the case of *pgr_dijkstra*
in 2.6 this can be done
SELECT * FROM *pgr_dijkstra*(end_vid:=3, start_vid:=2, edge_sql:='SELECT *
from edge_table');
CREATE FUNCTION mywarper2(...)
RETURN QUERY
from edge_table');
you will need to change your wrapper
RETURN QUERY
SELECT * FROM *pgr_dijkstra*('SELECT * from edge_table', 2, 3);
But the output columns are not affected, so other queries that use the
mywrapper2 should remain the same
Regards
Vicky
[1] https://twitter.com/jodygarnett/status/1054257267095171072
On Thu, Oct 25, 2018 at 12:42 AM Dave Potts <mrdapotts at gmail.com> wrote:
> Can we ensure that the following issues are taken care of
> Its clearly explained how to port old code to use the new systems for the
> last years worth of releases.
> Any attempt to use old signature method name with a new signature some
> results in some type of massive error along the lines your need to update
> you code.
> The current documentation is updated.
> Any new code or code that is being developed  has to use the new methods
> There is a lot of old code out there, we need a clear method of ensure it
> can be updated by somebody who has never seen pgrouting before
> On Wed, 24 Oct 2018 at 19:44, Vicky Vergara <vicky at georepublic.de> wrote:
>> Dear Users and developers
>> We would like to hear your feedback about:
>> That is described here:
>> https://github.com/pgRouting/admin/wiki/RFC3
>> The aim is to enforce positional notation on compulsory parameters and
>> allow named notation on optional parameters
>> That enforcement would take place on version 3.0.0 scheduled to be
>> released on September 2019.
>> We will appreciate your feedback.
>> Regards
>> The pgRouting team
>> Georepublic UG (haftungsbeschränkt)
>> Salzmannstraße 44,
>> 81739 München, Germany
>> Vicky Vergara
>> Operations Research
>> eMail: vicky at georepublic.de
>> Web: https://georepublic.info
>> Tel: +49 (089) 4161 7698-1
>> Fax: +49 (089) 4161 7698-9
>> Commercial register: Amtsgericht München, HRB 181428
>> CEO: Daniel Kastl
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20181025/d673d2d7/attachment.html>
More information about the Pgrouting-users mailing list
