[pgrouting-users] "procedure could not be found" when enabling pgRouting
David Lawrence Epstein
davideps at tauex.tau.ac.il
Tue Dec 29 03:16:16 PST 2020
Ah, that makes sense. I didn't see that there were multiple builds. Thank you Chintan.
From: Pgrouting-users <pgrouting-users-bounces at lists.osgeo.org> on behalf of Chintan Pathak <cp84 at uw.edu>
Sent: Tuesday, December 29, 2020 9:08 AM
To: pgRouting users mailing list <pgrouting-users at lists.osgeo.org>
Subject: Re: [pgrouting-users] "procedure could not be found" when enabling pgRouting
Hi David,
By the looks of it, your pgRouting binary seems to be for Postgres 9.6. This location (https://winnie.postgis.net/download/windows/pg13/buildbot/) seems to have the experimental pgRouting and PostGIS build for PG13.
Thanks
https://about.me/chintanpathak
On Mon, Dec 28, 2020 at 3:30 AM David Lawrence Epstein <davideps at tauex.tau.ac.il<mailto:davideps at tauex.tau.ac.il>> wrote:
Hi Folks,
I would like to add pgRouting to an existing installation (PostgreSQL = 13.0 64-bit (build 1914) and PostGIS = 3.0). I backup up my database using pgdump and downloaded Winnie pgRouting Experimental Build pgrouting-pg96-binaries-3.0w64gcc81. I copied the folders to the existing installation and overwrote. After rebooting, PostgreSQL started again and my database works as before. Since I already have PostGIS enabled, I just issued "CREATE EXTENSION pgrouting;" in a pgadmin4 query window. I received this error:
ERROR: could not load library "C:/Program Files/PostgreSQL/13/lib/libpgrouting-3.1.dll": The specified procedure could not be found. SQL state: 58P01
I see the file libpgrouting-3.1.dll in C:/Program Files/PostgreSQL/13/lib/. What procedure cannot be found? How can I enable pgRouting?
Thank you,
-david
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org<mailto:Pgrouting-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20201229/c27010e8/attachment-0001.html>
More information about the Pgrouting-users
