[pgrouting-users] Make pgrouting
Daniel Kastl daniel at georepublic.de
Thu Sep 3 06:28:25 PDT 2020
Hi Boris,
Do you have all build dependencies installed?
https://docs.pgrouting.org/latest/en/pgRouting-installation.html#dependencies
In particular you may be missing the postgresql-server-dev-xx package as
it's named in Debian/Ubuntu.
Looking at your error output it seems like you try to compile pgRouting 2.4.
There are already much newer versions in the meanwhile, so you may better
try those.
Best regards,
Daniel
On Thu, Sep 3, 2020 at 8:51 PM Boris Hikin <boris.hikin at gmail.com> wrote:
> Hi i am getting error when i make pgrouting
>  [  0%] Built target ProcessSQLFiles
> [  0%] Built target build-time-sql-directory
> [  1%] Building C object
> src/withPoints/src/CMakeFiles/withPoints.dir/one_to_one_withPoints.c.o
> In file included from /usr/include/pgsql/server/c.h:53:0,
>                  from /usr/include/pgsql/server/postgres.h:47,
>                  from
> /root/pgrouting-2.4.0/src/withPoints/src/./../../common/src/postgres_connection.h:34,
>                  from
> /root/pgrouting-2.4.0/src/withPoints/src/one_to_one_withPoints.c:30:
> /usr/include/pgsql/server/pg_config.h:14:30: fatal error:
> pg_config_x86_64.h: No such file or directory
>  #include "pg_config_x86_64.h"
> compilation terminated.
> make[2]: ***
> [src/withPoints/src/CMakeFiles/withPoints.dir/one_to_one_withPoints.c.o]
> Error 1
> make[1]: *** [src/withPoints/src/CMakeFiles/withPoints.dir/all] Error 2
> make: *** [all] Error 2
> do you know about this error ?
> Thank You
> Boris
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: https://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20200903/bcda78a8/attachment.html>
More information about the Pgrouting-users mailing list
