[pgrouting-users] Make pgrouting
Boris Hikin boris.hikin at gmail.com
Thu Sep 3 06:43:30 PDT 2020
Thank you for your replay Daniel,
Do you think it will be better to install it on debian or ubuntu ?
I installing it on centos 7
On Thu, 3 Sep 2020 at 16:28, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Boris,
> Do you have all build dependencies installed?
> https://docs.pgrouting.org/latest/en/pgRouting-installation.html#dependencies
> In particular you may be missing the postgresql-server-dev-xx package as
> it's named in Debian/Ubuntu.
> Looking at your error output it seems like you try to compile pgRouting
> 2.4.
> There are already much newer versions in the meanwhile, so you may better
> try those.
> Best regards,
> Daniel
> On Thu, Sep 3, 2020 at 8:51 PM Boris Hikin <boris.hikin at gmail.com> wrote:
>> Hi i am getting error when i make pgrouting
>>  [  0%] Built target ProcessSQLFiles
>> [  0%] Built target build-time-sql-directory
>> [  1%] Building C object
>> src/withPoints/src/CMakeFiles/withPoints.dir/one_to_one_withPoints.c.o
>> In file included from /usr/include/pgsql/server/c.h:53:0,
>>                  from /usr/include/pgsql/server/postgres.h:47,
>>                  from
>> /root/pgrouting-2.4.0/src/withPoints/src/./../../common/src/postgres_connection.h:34,
>>                  from
>> /root/pgrouting-2.4.0/src/withPoints/src/one_to_one_withPoints.c:30:
>> /usr/include/pgsql/server/pg_config.h:14:30: fatal error:
>> pg_config_x86_64.h: No such file or directory
>>  #include "pg_config_x86_64.h"
>> compilation terminated.
>> make[2]: ***
>> [src/withPoints/src/CMakeFiles/withPoints.dir/one_to_one_withPoints.c.o]
>> Error 1
>> make[1]: *** [src/withPoints/src/CMakeFiles/withPoints.dir/all] Error 2
>> make: *** [all] Error 2
>> do you know about this error ?
>> Thank You
>> Boris
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: https://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20200903/8d848e6c/attachment.html>
More information about the Pgrouting-users mailing list
