[pgrouting-users] osm_relations table does not get populated
Tokura Gou
tokura.gou at gmail.com
Sat Jun 3 10:10:12 PDT 2023
Hello Vicky and thanks for your response,
Maybe due to formatting issues the data and the command were not visible.
1. Data:
https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt
2. Exact command: osm2pgrouting -f home/map.osm -c
"/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U
[username] -W [password] --clean --tags --addnodes
On Fri, Jun 2, 2023 at 6:25 PM Vicky Vergara <vicky at erosion.dev> wrote:
> Hello,
> I can not reproduce your problem:
> What is needed:
> 1) The exact data that has been used, can be in the form of a link to a
> shared file, the wget command to download from osm.
> 2) the exact command that is been used (use mylogin and mypass instead of
> the real ones when posting the command)
> Regards
> Vicky
> On Fri, Jun 2, 2023 at 3:52 AM Tokura Gou <tokura.gou at gmail.com> wrote:
>> *Problem*
>> When running osm2pgrouting on a typical .osm file with the --addnodes
>> option, osm_relations table stays empty.
>> *To Reproduce*
>> osm2pgrouting -f home/map.osm -c "/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U [username] -W [password] --clean --tags --addnodes
>> *Expectation*
>> I use the --addnodes flag as per the documentation and I can see that
>> osm_nodes and osm_ways tables do get populated. However, osm_relations has
>> 0 records after running osm2pgrouting and "Final osm_relations:" is
>> never mentioned in the output:
>> Creating tables...
>> TABLE: ways_vertices_pgr created ... OK.
>> TABLE: ways created ... OK.
>> TABLE: pointsofinterest created ... OK.
>> TABLE: configuration created ... OK.
>> TABLE: osm_nodes created ... OK.
>> TABLE: osm_ways created ... OK.
>> TABLE: osm_relations created ... OK.
>> Opening configuration file: /usr/local/share/osm2pgrouting/mapconfig.xml
>> Parsing configuration
>> Exporting configuration ...
>> - Done
>> Counting lines ...
>> - Done
>> Opening data file: home/map.osm total lines: 175957
>> Parsing data
>> Current osm_nodes: 48000
>> Final osm_nodes: 48375
>> Current osm_ways: 6000
>> Final osm_ways: 6320
>> End Of file
>> Finish Parsing data
>> Adding auxiliary tables to database...
>> Export Ways ...
>> Creating indexes ...
>> Processing Points of Interest ...
>> Adding functions for processing Points of Interest ...
>> To process pointsOfInterest table:
>> osm2pgr_pois_update(radius default 200, within default 50)
>> - Using areas of (radius)mts on POIS
>> - Using edges that are at least (within) mts of each POI
>> POIS that do not have a closest edge is considered as too far
>> size of streets: 6320
>> Execution started at: Tue May 30 10:07:09 2023
>> Execution ended at: Tue May 30 10:07:21 2023
>> Elapsed time: 11.767 Seconds.
>> User CPU time: -> 1.12268 seconds
>> *Sample Data*
>> A sample .osm file is attached (please rename from txt to osm if
>> needed), however I have tried other .osm exports that contain osm relations
>> with the same result.
>> <https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt>
>> *Platform/versions*
>> SELECT version();
>> PostgreSQL 15.3 (Debian 15.3-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
>> SELECT postgis_full_version();
>> POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150" GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
>> SELECT pgr_version();
>> 3.4.1
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20230603/0622c8a9/attachment.htm>
More information about the Pgrouting-users
